OpenGL Outline Effects
Note that the OpenGL Outline Effects are OpenGL effects and only available on platforms supporting OpenGL.
GlOutlineBitmapBrushColorBlend
The OpenGl Outline Bitmap Brush Color Blend effect draws an outline to the configured image according to the performed configurations and additionally blends the image with the configured color.
Here you define the image that should be displayed. The image can be selected from the list of imported images in the "Choose Item" dialog.
Outline Width
This property configures the width of the outline.
Please note that this width shall not exceed the width of the thinnest lines that are outlined.
Outline Color
The color of the outline can be configured with this color property. The outline's color can be entered using the input fields. Alternatively, you can click on the color field on the left can, which opens the "Color Palette" Window where you can pick the desired color from a color palette.
Color
This property defines the constant color for modulating all input color channels (RGBA). This means, the displayed image is blended with the color configured with this property according to the Blending options configured below.
Blending Options
To configure the color blending, several color blend options are available.
More details regarding color blending properties in CGI Studio can be found at the SolidColorBrushColorBlend effect.
Further information about blending in general are given in chapter Blending.
GlOutlineTextBrushBlend
The OpenGl Outline Text Brush Blend effect draws an outline to a configured text according to the performed configurations.
Text
There is a simple text input field to input the text.
Text Color
The color of the text can be entered using the input fields. Alternatively, you can click on the color field on the left, which opens the "Color Palette" Window where you can pick the desired color from a color palette.
Outline Width
Outline Color
Please note that this effect should not be used with any text cache type other than Bitmap Cache.
