FeatStd CMake Switches
- Note:
- For detailed information on FeatStd configuration please see Application Development > FeatStd > FeatStd Features
| V2.10.0 | V3.0.0 |
| CGIFEATURE_ENABLE_LOG has been unified with FEATSTD_ENABLE_LOG | FEATSTD_LOG_ENABLED |
| CGIFEATURE_ENABLE_MEMORYPOOL has been unified with FEATSTD_ENABLE_MEMORYPOOL | FEATSTD_MEMORYPOOL_ENABLED |
| CGIFEATURE_ENABLE_MEMORY_STATISTIC has been unified with FEATSTD_ENABLE_SYSTEM_MEMORY_STATISTIC | FEATSTD_SYSTEM_MEMORY_STATISTIC_ENABLED |
| CGIFEATURE_SYSTEM_MEMORY_STATISTIC_FILE_AND_LINE_TRACKING has been unified with FEATSTD_ENABLE_SYSTEM_MEMORY_STATISTIC_FILE_AND_LINE_TRACKING | FEATSTD_SYSTEM_MEMORY_STATISTIC_FILE _AND_LINE_TRACKING_ENABLED |
| CGIFEATURE_FRACTIONAL_NUMBER_TYPE has been unified with FEATSTD_FRACTIONAL_NUMBER_TYPE | FEATSTD_FRACTIONAL_NUMBER_TYPE |
| CGIFEATURE_ENABLE_MONITOR has been unified with FEATSTD_ENABLE_MONITOR | FEATSTD_MONITOR_ENABLED |
| COURIER_ENABLE_IPC has been unified with FEATSTD_ENABLE_IPC | FEATSTD_IPC_ENABLED |
| FEATSTD_ENABLE_THREADSAFETY | FEATSTD_THREADSAFETY_ENABLED |
| FEATSTD_ENABLE_UNITTEST_FRAMEWORK | FEATSTD_UNITTEST_FRAMEWORK_ENABLED |
| FEATSTD_ENABLE_DLT | FEATSTD_DLT_ENABLED |
- Note:
- Refer to the Candera 3.0.0 CMake Changelog to learn about Candera V3.0.0 CMake switch modifications.
