Command-line usage
Below are the basic steps for running CgiRemoteControl.exe. Because CgiRemoteControl.exe only triggers plugin processing, a separate plugin implementation is required.
Execution Format
Run CgiRemoteControl.exe from a script or command prompt using the following format. See the next section for the runtime arguments.
CgiRemoteControl.exe --SolutionFilePath "<path>.scs" [--PlugInControl "<command>"] [<configFile>]
Arguments
Specifying the Solution Path (Required)
--SolutionFilePath <path>
Specifies the path to the .scs solution to load (relative or absolute path is acceptable).
Example:
--SolutionFilePath "C:/path/test.scs"
Specifying the Plugin Command (Optional)
Specifies the plugin command to execute during processing. If omitted, the plugin’s OnPluginControl implementation is not invoked.
Example:
--PlugInControl "BuildHost 4711"
Specifying the Configuration File (Optional)
<configFile>
Specifies the XML configuration file name to use. If omitted, the default CgiRemoteControlConfig.xml is used.
Example:
C:/path/CgiRemoteControlConfig.xml
Checking Execution Logs
The console prints the selected configuration file name, resolved SCHostPath, SolutionFilePath, PlugInControl, TimeoutMilliseconds, and so on. When processing completes, a final message is printed. You can check the process exit code with echo %ERRORLEVEL%.
Exit Code
Return codes indicate success or failure (0 for success; non‑zero for failure).
| Code | Description |
| 0 | Success |
| -1 | Configuration file not found |
| -2 | Permission error accessing the configuration file |
| -3 | Invalid configuration file format |
| -4 | Error loading the solution |
| -5 | SCHost not found |
| -6 | Process timed out |
| -7 | Process cancelled |
| -8 | General error |
Code Execution Example
D:/work/bin/SceneComposer>CgiRemoteControl.exe --SolutionFilePath "C:/path/test.scs" --PlugInControl "BuildHost 4711"
[2025-01-17 10:42:05.954] [Info] Using configuration file: CgiRemoteControlConfig.xml
[2025-01-17 10:42:06.033] [Info] Resolved SCHostPath: C:/path/SCHost.dll
[2025-01-17 10:42:06.033] [Info] Loaded configuration:
[2025-01-17 10:42:06.033] [Info] SCHostPath: C:/path/SCHost.dll
[2025-01-17 10:42:06.033] [Info] SolutionFilePath: C:/path/test.scs
[2025-01-17 10:42:06.033] [Info] PlugInControl: BuildHost 4711
[2025-01-17 10:42:06.033] [Info] TimeoutMilliseconds: 1800000
[2025-01-17 10:42:06.033] [Info] CgiRemoteControl Process start.
Info: The following licenses were acquired successfully: 2D, 3D, Globalization, SmartImporter, AssetLibraryVerification, Safety.
0000000.574 [0x00009BC0] WARN Controls Failed to create source stream object. Possibly no VideoStreamer is registered. {VideoStreamBehavior.cpp(143): VideoStreamBehavior}
Info: Starting schema validation of file:
Info: 1/17/2025 10:42:15 AM:OnSolutionChanged
Warning: The application specification file is missing or invalid!
[2025-01-17 10:42:15.021] [Info] Solution loaded successfully.
Info: 1/17/2025 10:42:15 AM:test log start
Info: 1/17/2025 10:42:15 AM:OnPluginControl BuildHost 4711 Processing...10%
Info: 1/17/2025 10:42:16 AM:OnPluginControl BuildHost 4711 Processing...50%
Info: 1/17/2025 10:42:17 AM:OnPluginControl BuildHost 4711 Processing...100%
Info: 1/17/2025 10:42:17 AM:test log end
[2025-01-17 10:42:17.063] [Info] Plugin executed successfully.
[2025-01-17 10:42:17.063] [Info] CgiRemoteControl Process end.
>echo %ERRORLEVEL%
0
