# Wayland Linux BSP
# Wayland Linux BSP: Prerequisites
#### **Hardware: Raspberry Pi 5 Board**
CGI Studio has been tested on the <span style="background-color: rgb(0, 0, 0);">**<span style="background-color: rgb(255, 255, 255);">Raspberry Pi 5</span>**<span style="background-color: rgb(255, 255, 255);"> </span></span><span style="background-color: rgb(255, 255, 255);">B</span>oard.
##### <a class="anchor" id="bkmrk--0"></a>CMake
In order to build Candera, the Meta build system CMake needs to be installed with at least version mentioned <span style="color: rgb(230, 126, 35);">[here.](https://doc316en.candera.eu/books/build-system-setup/page/prerequisites)</span>
##### <a class="anchor" id="bkmrk--1"></a>Linux Toolchain (BSP)
<div class="contents" id="bkmrk-linux-version-5.4.3-"><div class="contents"><div class="textblock">
- SD card image was prepared with <span style="color: rgb(230, 126, 35);">[Raspberry Pi Imager](https://www.raspberrypi.com/software/)</span>.
- Raspberry Pi OS based on Debian Trixie was tested with a Debian Trixie build machine.
    - Install crossbuild-essential-arm64
        su
        apt-get -y update && \
        apt-get -y install crossbuild-essential-arm64
    - Make the SD card accessible in your build machine.
        Copy the /usr/lib and /usr/Include folders  from the SD card to your build machine. This can also be done with e.g. scp.
        #find the mount point of the SD card created with Raspberry Pi Imager
        su
        mkdir /opt/raspberry
        mkdir /opt/raspberry/sysroot64
        mkdir /opt/raspberry/sysroot64/usr
        cd /opt/raspberry/sysroot64/usr
        cp -ar <mount point of the sd card>/usr/lib  <mount point of the sd card>/usr/include .
</div></div><div class="contents"><div class="textblock"><dl class="note"><dd><p class="callout info">SD Card image, SDK and cross-compiler/s are not part of the delivery and have to be provided by the customer.</p>
</dd></dl></div></div></div>#### **Hardware: NXP i.MX8QMMEK Board**
CGI Studio has been tested on **NXP i.MX8QMMEK** board.
##### <a class="anchor" id="bkmrk-"></a>CMake
##### <a class="anchor" id="bkmrk--2"></a>Linux Toolchain (BSP)
<div class="contents" id="bkmrk-linux-version-5.4.3--1"><div class="contents"><div class="textblock">
- Linux version 5.4.3-lts-lf-5.4 (GCC version 9.2.0), Poky 5.4.3 (Zeus) was used to test this release with Weston 7.0.0 (Wayland 1.17.0).
- SD card image and SDK was prepared following the NXP’s Linux user guide.
- Graphic driver: Vivante (OpenGL ES 2.0)
</dd></dl></div></div></div>#### <a class="anchor" id="bkmrk--3"></a>Known Limitations
In case open source graphic driver is used (e.g. Etnaviv) following limitations could occur due to driver limitations:
<div class="contents" id="bkmrk-issue-with-shader%2Fs-"><div class="textblock">
- issue with shader/s due to limited number of vectors
- MSAA was not supported
</div></div>####
**Hardware: STM32MP157C-DK2 board**
CGI Studio has been tested on STM32MP157C-DK2 board.
##### <a class="anchor" id="bkmrk--4"></a>CMake
##### <a class="anchor" id="bkmrk--5"></a>Linux Toolchain (BSP)
<div class="contents" id="bkmrk-linux-version-5.10.1"><div class="contents"><div class="textblock">
- Linux version 5.10.10 (GCC version 9.3.0), ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 3.1-openstlinux-5.10-dunfell-mp1-21-03-31 (dunfell) was used to test this release with Weston 8.0.0 (Wayland 1.18.0).
- SD card image and SDK was prepared following the STM’s Linux user guide.
</div><div class="textblock"><dl class="note"><dd><p class="callout info">SD Card image, SDK and cross-compiler/s are not part of the delivery and have to be provided by the customer.</p>
</dd></dl></div></div></div>##### <a class="anchor" id="bkmrk--6"></a>Known Limitations
<div class="contents" id="bkmrk-issue-with-shader%2Fs--0"><div class="textblock">
</div></div>#### **Hardware: NXP i.MX 8MN board**
CGI Studio has been tested on NXP i.MX 8MN board.
##### <a class="anchor" id="bkmrk--7"></a>CMake
##### <a class="anchor" id="bkmrk--8"></a>Linux Toolchain (BSP)
<div class="contents" id="bkmrk-linux-version-5.4.70"><div class="contents"><div class="textblock">
- Linux version 5.4.70 (GCC version 9.2.0), Poky 5.4 (Zeus) was used to test this release with Weston 9.0.0 (Wayland 1.18.0).
- SD card image and SDK was prepared following the boards user guide.
- Graphic driver: Etnaviv (OpenGL ES 3.0)
</dd></dl></div></div></div>##### <a class="anchor" id="bkmrk--9"></a>Known Limitations
<div class="contents" id="bkmrk-issue-with-shader%2Fs--1"><div class="textblock">
</div></div>####
**Hardware: NXP i.MX 8MM board**
CGI Studio has been tested on NXP i.MX 8MM board.
##### <a class="anchor" id="bkmrk--10"></a>CMake
##### <a class="anchor" id="bkmrk--11"></a>Linux Toolchain (BSP)
<div class="contents" id="bkmrk-linux-version-5.4.70-0"><div class="contents"><div class="textblock">
- Graphic driver: Etnaviv (OpenGL ES 2.0)
</dd></dl></div></div></div>##### <a class="anchor" id="bkmrk--12"></a>Known Limitations
<div class="contents" id="bkmrk-issue-with-shader%2Fs--2"><div class="textblock">
</div></div>
# Running the CGI Player Demo Application on Linux with a Wayland Display Server
Copy the application and the asset to the target in /home/root folder. This can be done by copying the filed to the SD card containing the file system or via ssh (scp).
#### Logging Output and Key Input
Use TeraTerm or another terminal software to connect to the target via micro-USB (debugger) to receive logging output and use key input.
BaudRate needs to be setup to 115200 8/n/1/n.
#### Loading and Running the Application
On target via TeraTerm, navigate (change directory) into the /home/root folder and run the applications with following command:
./<app-name> <asset-name>.bin
# Building Own Application for Linux with a Wayland Display Server
#### Generate Makefiles with CMake
For general information about CGI Studio Build System and CMake properties available to configure Candera applications refer to <span style="color: rgb(230, 126, 35);">[CGI Studio Build System](https://doc316en.candera.eu/books/build-system-setup/chapter/build-system-overview)</span>
<div class="contents" id="bkmrk-open-a-terminal.-set"><div class="contents"><div class="textblock">
1. Open a terminal.
    $source /<path to the Yocto SDK installation>/environment-setup-<platform specific suffix e.g. aarch64-poky-linux>
    - Folder containing top-level "CMakeLists.txt", e.g. /cmake/Candera/Player <div class="image"><div drawio-diagram="2938"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1677567539.png" alt=""/></div>
        </div>
    - Root directory for build artifacts <div class="image"><div drawio-diagram="2939"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1677567561.png" alt=""/></div>
        </div>
6. Configure
    - Specify Unix Makefiles as generator for the project.
    - Specify tool-chain file for cross-compiling. <div class="image"><div drawio-diagram="2940"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1677567581.png" alt=""/></div>
        </div>
    /cgi_studio_devices/src/Wayland/ToolchainFiles/GCC-toolchain-Wayland-Linux.txt
    If Vulkan support is required, use the Vulkan-specific toolchain file.
    /cgi_studio_devices/src/Wayland/ToolchainFiles/GCC-toolchain-Wayland-Vulkan-Linux.txt
8. Adapt the CMake settings, if necessary, e.g.:
    - CMAKE\_BUILD\_TYPE-&gt; Debug or Release.
    - Enable/disable features.
    - Press Configure.
9. Press Generate.
</div></div></div>#### Building Application
<div class="contents" id="bkmrk-make-sure-that-the-e"><div class="textblock"><dl class="note"><dd><p class="callout info">Make sure that the environment variables for the Yocto SDK are set in the terminal! Either reuse the terminal used to start CMake for building the Player or call the environment setup script again.</p>
<div class="contents" id="bkmrk-open-cmake-gui-and-c"><div class="textblock">
1. Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake.
</div></div><div class="contents" id="bkmrk-for-couriersampleapp"><div class="textblock"><dl class="note"><dd><p class="callout info">For CourierSampleApp and CitDemoApp asset file must be created with a matching SCHost.dll as the SCHost.dll for the CourierSampleApp and CitDemoApp contain specialized Widgets.</p>
</dd></dl></div><div class="textblock"><dl class="note"><dd>#### Vulkan Packaging Workflow
After a successful Vulkan build:
1. Build and copy ANGLE Vulkan Libraries:
    Build your own ANGLE Vulkan libraries for your target platform:
    \- libEGL.so
    \- libGLESv2.so
    These libraries must match your target architecture.
    Copy into the same directory where the Player executable is located (the build output directory).
2. Run Packaging Script
    From the build directory, execute the `package_player.sh` script. After execution, a folder named **vulkan** will be created.
    Inside this folder you will find **Player.run** this is the only required output package.
3. Run the packaged Player using `./Player.run Your_Asset.bin`
<div class="contents" id="bkmrk-"><div class="textblock"><dl class="note"></dl>
</div></div>
