# R-Car D3 Custom Integrity BSP
# R-Car D3 Custom Integrity BSP: Prerequisites
#### <a class="anchor" id="bkmrk-"></a>Hardware: Renesas RCarD3 Draak board
CGI Studio has been tested on Renesas RCarD3 Custom Draak board.
#### <a class="anchor" id="bkmrk--0"></a>CMake
In order to build Candera, the Meta build system CMake needs to be installed with at least version mentioned <span style="color: rgb(230, 126, 35);">[here](https://doc316en.candera.eu/books/build-system-setup/page/prerequisites)</span>.
CMake is able to create the cross compilation make files that can be used with Green Hills MULTI compiler.
#### <a class="anchor" id="bkmrk--1"></a>MinGW
To allow cross compilation with makefiles, MinGW 5.1.6 was used for this release.
#### <a class="anchor" id="bkmrk--2"></a>Green Hills Toolchain
The build tool chain is not part of the delivery. Green Hills MULTI compiler, Green Hills Integrity and the according Renesas BSP and RGL driver have to be obtained directly from Green Hills or Renesas and installed according to their installation guide.
CGI Studio was tested with **MULTI IDE 7.1.6, Compiler 2018.1.4** and **INTEGRITY for ARM v11.7.7**
The Green Hills Probe was setup with **Green Hills Probe Firmware Version 5.6.4, configuration rcar-d3.ghpcfg (included in BSP)**.
#### <a class="anchor" id="bkmrk--3"></a>Renesas Graphics Library
The graphics driver is not part of this release. CGI Studio was integrated and tested with the D3Hx RGL SGX540 driver Version V1.0
# Running the Player Demo Application on R-Car D3 Custom Integrity
#### <a class="anchor" id="bkmrk-"></a>Preparations
Make sure to have an implementation of cgi\_studio\_3psw\\src\\RCarD3\\enable\_display\\RCarD3\_custom\_EnableDisplays.h in the file cgi\_studio\_3psw\\internal\\Devices\\RCarD3\\enable\_display\\RCarD3\_custom\_EnableDisplays.c in order to set the GPIO pins in a way the displays work. Make also sure to copy the flash wrapper layer to "cgi\_studio\_3psw\\internal\\Devices\\RCarD3\\storage\_driver\_wrapper\_layer" where it is expected to be when using eMMC resp. QSPI as asset repository.
#### <a class="anchor" id="bkmrk--0"></a>Logging Output and Key Input
Use any terminal software to connect to the target via COM to receive logging output and use key input. BaudRate needs to be set to 115200.
#### <a class="anchor" id="bkmrk--1"></a>Download the Application
To download and debug the application you need a Green Hills probe according to the Prerequisites. In the Connection Organizer open the default.con from your BSP (devtree-arm64).
#### <a class="anchor" id="bkmrk--2"></a>Monolith Application
In the MULTI launcher select “Open debugger” and direct to your build folder. There choose the Monolith (this is the file without file extension and the application name and the word Monolith in it). Then hit F5 and connect to target via “Green Hills Probe Connection (mpserv) for SSFTxxx\_RcarD3\_10inch”. Choose “Download to RAM”. After the application is downloaded, the Player application starts. In the terminal press “h” to get the menu.
#### <a class="anchor" id="bkmrk--3"></a>Loading the asset
By default, the Player demo application has the asset file added by the linker. It will be loaded to RAM together with the application. You have to select the asset file in CMake via the variable ASSET\_TARGET\_LOCATION before you build the application.
# Building Own Application for R-Car D3 Custom Integrity
#### <a class="anchor" id="bkmrk-"></a>Generate Makefiles with CMake
For general information about CGI Studio Build System and CMake properties available to configure Candera applications refer to <span style="color: rgb(230, 126, 35);">[CGI Studio Build System](https://doc316en.candera.eu/books/build-system-setup)</span>.
To configure and generate makefiles for compiling the Player, follow below steps:
<div class="contents" id="bkmrk-point-cmake-to-sourc"><div class="contents"><div class="textblock">
    - Folder containing top-level "CMakeLists.txt", e.g. \\cmake\\Candera\\Player
3. Configure
    - \\cgi\_studio\_devices\\src\\RCarD3\\ToolchainFiles\\MULTI-toolchain-RCarD3\_custom.txt
    - CMAKE\_BUILD\_TYPE-&gt; Debug or Release
    - Press Configure
6. Press Generate
</div></div></div>#### <a class="anchor" id="bkmrk--0"></a>Building Application
Via the CMake variable CGIDEVICE\_BSP\_CFG\_NAME, it is possible to choose the BSP library configuration. By default this is set to release (rel), however, it is also possible to choose debug (dbg), checked (chk) resp. coverage (cov).
On the custom board display id 1 was used for all our. Please make sure to have set display id to 1 in Scene Composer. If you want to change this, this also has to be changed for our samples in CMake via the variable CGIDEVICE\_DISPLAY\_ID.
For this board it is intended to use a shader compiler. By default, the 2D shaders are pre-compiled and already linked to the sample. This is done via the CMake variables CANDERA\_EXTERNAL\_SHADER\_BUILDER\_HEADER\_INCLUDE, CANDERA\_EXTERNAL\_SHADER\_BUILDER\_HEADER\_PATH and CANDERA\_EXTERNAL\_SHADER\_BUILDER\_SOURCE\_PATH. If you want to change this, first uncheck RCARD3\_EXTERNAL\_SHADER\_BUILDER\_USAGE\_DEFAULT, then it is possible to e.g. delete the value of the above mentioned variables in order to not use pre-compiled shaders. For all the other shaders, the compilation is done via plugin in CGI Studio. Please make sure to have the RCarD3 Shader Compiler Plugin (can be found under File/Preferences) set to “Binary”. Additionally, set the absolute path to the shader compiler \*.exe. If the RCarD3 Shader Compiler Plugin is set to “Text”, the shader compiler is not used at all.
It is possible to have the asset stored in the eMMC resp. QSPI flash instead of having it linked to the monolith. Use the writing tool to store the asset into the flash. Make also sure to copy the flash wrapper layer to "cgi\_studio\_3psw\\internal\\Devices\\RCarD3\\storage\_driver\_wrapper\_layer" where it is expected to be when using eMMC resp. QSPI as asset repository. In CMake it is required to change the variable RCARD3\_ASSET\_LOCATION from “Monolith” to “eMMC” resp. “QSPI”. Additionally, it is necessary to verify the path to the Flash tool (RCARD3\_FLASH\_TOOL\_PATH) in order to link the correct libraries.
