# Target setup for iOS
# iOS Player Build Guide
Before you begin, it’s recommended to prepare and verify the connection between your Mac and your iPhone.
#### Checking SDK Compatibility
First, make sure that the SDK version in Xcode is compatible with your iPhone’s iOS version.
To do this:
1. Create a new project in Xcode (for example, “HelloWorld”).
    <div drawio-diagram="8773"><img src="https://doc316en.candera.eu/uploads/images/drawio/2025-11/drawing-7-1763597755.png" alt="drawing-7-1763597755.png"/></div>
2. Try running it on your device.
3. If any warnings appear, follow the instructions until the project successfully runs on the iPhone.
    <div drawio-diagram="8774"><img src="https://doc316en.candera.eu/uploads/images/drawio/2025-11/drawing-7-1763597842.png" alt="drawing-7-1763597842.png"/></div>
This step ensures that your device pairing, certificates, and accounts are set up correctly.
#### Generating the Project
Before generating the project:
Make sure that your **Asset.bin** file is placed in the root directory.
Go to the directory where you downloaded your client and create a folder named build.
Ensure that **CMake** is installed, then run:
cmake \
  -G Xcode \
  -DCMAKE_TOOLCHAIN_FILE=../cgi_studio_devices/src/iOS/Toolchain_Files/GCC-toolchain-iOS-Device.txt \
  ../cmake/Candera/Player
After the project is generated, open Xcode and load the created project.
#### Installing Player on iOS
1. Launch Xcode and open the **Player\_iOS\_64** project.
    <div drawio-diagram="8775"><img src="https://doc316en.candera.eu/uploads/images/drawio/2025-11/drawing-7-1763598005.png" alt="drawing-7-1763598005.png"/></div>
2. Make sure that **Developer’s iPhone** is selected as the target device.
    <div drawio-diagram="8776"><img src="https://doc316en.candera.eu/uploads/images/drawio/2025-11/drawing-7-1763598059.png" alt="drawing-7-1763598059.png"/></div>
3. If something else is selected, click on the device selector and choose the correct iPhone.
    If your iPhone does not appear, disconnect and reconnect the USB cable.
4. Click the \[ Play \] button or select \[ Product &gt; Run \] and wait for the app to build and install and launch on the device.
    <div drawio-diagram="8777"><img src="https://doc316en.candera.eu/uploads/images/drawio/2025-11/drawing-7-1763598131.png" alt="drawing-7-1763598131.png"/></div>
5. Once you see the Asset running on the iPhone screen, click \[ Stop \] in Xcode and disconnect the device.
Everything should now be functioning correctly.
#### Replacing Asset.bin
To replace the Asset file:
1. Go to the project root directory.
2. Replace the existing **Asset.bin** file with your new version.
#### Troubleshooting
If an error appears during installation, it may indicate that your developer account needs to be trusted on the iPhone.
<div drawio-diagram="8780"><img src="https://doc316en.candera.eu/uploads/images/drawio/2025-11/drawing-7-1763598374.png" alt="drawing-7-1763598374.png"/></div>
<div drawio-diagram="8781"><img src="https://doc316en.candera.eu/uploads/images/drawio/2025-11/drawing-7-1763598415.png" alt="drawing-7-1763598415.png"/></div>
To trust the developer:
1. On the iPhone, go to \[ Settings &gt; General \].
    <div drawio-diagram="8782"><img src="https://doc316en.candera.eu/uploads/images/drawio/2025-11/drawing-7-1763598484.png" alt="drawing-7-1763598484.png"/></div>
2. Scroll down and open **VPN &amp; Device Management**.
    <div drawio-diagram="8783"><img src="https://doc316en.candera.eu/uploads/images/drawio/2025-11/drawing-7-1763598537.png" alt="drawing-7-1763598537.png"/></div>
3. Select **your account email**.
    <div drawio-diagram="8784"><img src="https://doc316en.candera.eu/uploads/images/drawio/2025-11/drawing-7-1763598591.png" alt="drawing-7-1763598591.png"/></div>
4. Tap **Trust** <span style="color:rgb(230,126,35);"><developer@example.com>.</span>
    <div drawio-diagram="8785"><img src="https://doc316en.candera.eu/uploads/images/drawio/2025-11/drawing-7-1763598660.png" alt="drawing-7-1763598660.png"/></div>
5. Confirm by choosing \[ Allow \], then try installing the app again.
    <div drawio-diagram="8786"><img src="https://doc316en.candera.eu/uploads/images/drawio/2025-11/drawing-7-1763598714.png" alt="drawing-7-1763598714.png"/></div>
