# iMX6 Linux ARM
# iMX6 Linux ARM: Prerequisites
#### <a class="anchor" id="bkmrk-"></a>Hardware: Freescale iMX6 SABRE
CGI Studio has been tested on Freescale iMX6 SABRE Lite and Automotive Infotainment
#### <a class="anchor" id="bkmrk--0"></a>Linux Board Support Package (BSP)
The Freescale Release BSP imx-3.14.38-6QP\_ga was used for SABRE Automotive Infotainment. For SABRE Lite and commercial projects the FSL Community BSP is recommended. For integration the BSP based on the fido branch (poky 1.8.1) was used (see [https://github.com/Freescale/fsl-community-bsp-platform](https://github.com/Freescale/fsl-community-bsp-platform)).
#### <a class="anchor" id="bkmrk--1"></a>Vivante Graphics Driver for Linux
CGI Studio was integrated and tested on top of the drivers included in the above mentioned BSPs (gpu-viv version 5.0.11)
#### <a class="anchor" id="bkmrk--2"></a>CMake
In order to generate makefiles for building Candera applications, the Meta build system CMake needs to be installed with at least version 3.5.2.
#### <a class="anchor" id="bkmrk--3"></a>Known Issues
Intitialising vectors in shaders like, e.g. vec3 xyz = new vec3(0.0) in some cases leads to unexpected behaviour. Workaround: initialise with vec3 xyz = new vec3(0.0, 0.0, 0.0);
# Running the Player Demo Application on iMX6 Linux
#### <a class="anchor" id="bkmrk-"></a>iMX6 System Preparation
For instructions how to install the toolchain please refer to the Yocto Project's Quickstart and Application Developer's Guide.
The application and asset can be copied into the folder /root on the SD-Card with the target root file system, and executed like this:
# Connect TeraTerm to COM1 at
# bits per second: 115200
# data bits: 8
# parity: none
# stop bits: 1
# flow control: none
# load the GPU Driver
modprobe galcore.ko
cd /root
# run CGIApplication
./CGIApplication_ARM_Linux_iMX6_Target_GCC <AssetLibrary>
Both applications use a target asset file.
#### <a class="anchor" id="bkmrk--1"></a>Additional Steps for Frame Buffer Blending
If two display planes shall be blended on the iMX6 target, using Candera with the frame-bufffer implementation of the iMX6 drivers, following code can be used to resize and unblank the overlay plane. This is not avaliable if X11 is used.
# Use fbset to find out settings of /dev/fb0
fbset -fb /dev/fb0
# Example output
#mode "1920x1080-60"
#    # D: 148.500 MHz, H: 67.500 kHz, V: 60.000 Hz
#    geometry 1920 1080 1920 1080 16
#    timings 6734 148 88 36 4 44 5
#    hsync high
#    vsync high
#    rgba 5/11,6/5,5/0,0/0
#endmode
# Set /dev/fb1 to the same settings as /dev/fb0
fbset -fb /dev/fb1 -g 1920 1080 1920 1080 16
fbset -fb /dev/fb1 -t 6734 148 88 36 4 44 5
fbset -fb /dev/fb1 -hsync high
fbset -fb /dev/fb1 -vsync high
# Unblank /dev/fb1
echo 0 > /sys/class/graphics/fb1/blank
# Building Own Application for iMX6 Linux
#### <a class="anchor" id="bkmrk--0"></a>Compile Tool Chain Preparations
To add the header and lib directories to your path, you might have to call a script to set your environment variables:
<p class="callout info">This step is needed when you use our build-setup description.</p>
cd /opt/poky/x.y.z (where x.y.z is your BSP version)
sudo chmod +x environment-setup-cortexa9hf-vfp-neon-poky-linux-gnueabi
source environment-setup-cortexa9hf-vfp-neon-poky-linux-gnueabi
<p class="callout info">Should be done every new build (environment variables are valid per terminal session)</p>
<div class="contents" id="bkmrk-"><div class="contents"><div class="textblock">
</div></div></div>#### <a class="anchor" id="bkmrk--1"></a>Generate Makefiles with CMake
CMAKE-GUI has to be run on same terminal after source command (step 1)
To configure and generate makefiles for compiling the Player for IMX6 Linux, follow below steps:
<div class="contents" id="bkmrk-point-cmake-to-sourc"><div class="contents"><div class="textblock">
    - Folder containing top-level "CMakeLists.txt", e.g. \\cmake\\Candera\\Player
3. Configure
    - Specify Unix Makefiles as generator for the project
    - Specify toolchain file for cross-compiling
    - Select the toolchain file \\cgi\_studio\_candera\\cmake\\toolchain-files\\GCC-toolchain-iMX6-Linux-yocto.txt
    - Press Finish
    - Afterwards “Configure” has to be pressed as often as there is still some entry red or the necessary configuration (e.g. CANDERA\_TEXTSHAPER = harfbuzz) is done.
4. Press Generate
</div></div></div>If the package supports "harfbuzz" as CANDERA\_TEXTSHAPER please set this entry appropriately because by default it is set to "ComplexLib". Resume the configuration by pressing “Configure” again.
<p class="callout info">Configure COURIER\_PLATFORM and COURIER\_PLATFORM\_CONFIG parameters</p>
#### <a class="anchor" id="bkmrk--2"></a>Building Application
The output file can be found in your build directory's subfolder CGIApplication.
Copy the application to a dedicated folder in the NFS root and start it as described in the previous chapter.
