# UI Examples
# A simple configurable plugin
<a class="anchor" id="bkmrk-"></a>Creating a plugin that registers a configuration and uses the default configuration editor.
<a class="anchor" id="bkmrk--0"></a>The Plugin class.
The first step is to create a class that implements the IPluginService interface. This is the type that will be instantiated by Scene Composer.
 public class SimpleConfigurablePlugin : IPluginService
##### <a class="anchor" id="bkmrk--1"></a>Implementing IPlugin
Next we must implement the IPluginService interface members.
 public string <a class="code" href="http://dev.doc.cgistudio.at/APILINK/group___behaviors_mixed_reality.html#gga70813433b87d1347efaf56d755a186c1aa161dba378f926eef1e116dd38c4b6c6">Name</a>
   get { return return this.GetType().Name; }
 public string Description
    get { return "A plugin that has configuration"; }
 public string Version
   get { return "1.1.1"; }
 public IEnumerable<int> FeatureIds
   get { return null; }
##### <a class="anchor" id="bkmrk--2"></a>The Initialize method
First we need to register a custom cinfiguration interface and register to recieve an event when the configuration is loaded.
   var loader = unityContainer.Resolve<IConfigurationManager>().RegisterConfigurationInterface<ISimpleConfiguration>();
   loader.ConfigLoaded += loader_ConfigLoaded;
Then we need to registter a defualt configuration definition of our custom type with the UI definition manager
 unityContainer.Resolve<UIDefinitionManager>().RegisterUIElement
   new DefaultConfigDefinition<ISimpleConfiguration>(category: OptionCategories.Plugins, name: "Default Config")
The full code for the example with extra info:
##### <a class="anchor" id="bkmrk--3"></a>SimpleConfigurablePlugin.cs
  using System;
  using System.Collections.Generic;
  using System.Linq;
  using System.Text;
  using Feat.UIComposition.UIConfiguration;
  using FTC.SDKInterface.Plugins;
  using FTC.SDKInterface.Services;
  using Feat.UIComposition.Config;
  using System.ComponentModel;
  using Feat.UIComposition;
  using Feat.UIComposition.Commanding;
  using Feat.UIComposition.Menus;
  using FTC.SDKInterface.Constants;
  using Feat.Metadata.PropertyGrid;
  namespace UIPlugins
     /// <summary>
     /// This examples demos a simple plugin that registers a configuration with FTC
     /// and uses the default configuration editor in scene composer.
     /// </summary>
        public string Name
           get { return this.GetType().Name; }
        public void Initialize(IUnityContainer unityContainer)
           // We register the configuration interface with the configuration manager.
           // The object that is returned allow access to the config instance, allows the saving and loading of the configuration
           // and allows the registration of events pertinent to the configuration, such as the loading of the config or a property change.
           // Explicit loading or saving of the configuration is not necessary, as FTC will load the config the first time
           // it is accessed, and will save it when the application closes.
           // The plugin developer can however explicitly save the configuration or reload it from disk if necessary.
           //We register to receive events when the configuration is loaded.
           // We register with the ui definition manager a default configuration definition with the type of our custom config interface.
           // We also specify the category in which to place the configuration, and the name to use for the section.
        /// <summary>
        /// Event handler for when the configuarion is loaded.
        /// </summary>
        /// <param name="sender"></param>
        /// <param name="e"></param>
        void loader_ConfigLoaded(object sender, ConfigLoadedEventArgs<ISimpleConfiguration> e)
           // If the configuration was not loaded successfully, either this is the first time it it has been created
           // and there was no configuration to load, or the configuration file was corrupted.
           // Either way we initialize complex configuration properties, that could not be initialized with the DefaultValue attribute.
           if (!e.ConfigLoadedSuccessfully)
              e.Instance.OtherParameters = new List<string>
                 "Param1 "
     /// <summary>
     /// The configuration interface. This interface will be implemented by Scene Composer and offered to the plugin
     /// when it is registered with the Configuration manager service.
     /// </summary>
     /// All properties declared  in the configuration interface must conform to standard .NET XMLSerializer standards.
     /// If we use the default editor for configurations then we can control how the property grid displays the content.
     /// The CategoryDisplayInfo attribute specifies that the default category should have no header. \n
     /// The DefaultValue attribute specifies the default value to be used for the property, either when resetting the value or
     /// when the configuration is first created. \n
     /// The Category attribute dictates the category in which the property grid will display the property. \n
     /// The DisplayName attribute specifies what name the property grid should use for this property, if the attribute is not specified,
     /// Scene composer will use the actual property name.\n
     /// The Browsable attribute allows the hiding of properties in the property grid.
     [CategoryDisplayInfo("", StyleKey = PropertyGridConstants.NoHeaderCategory)]
     public interface ISimpleConfiguration : IConfiguration
        [DefaultValue("format C:")]
        string CommandToExecute { get; set; }
        [DefaultValue(true)]
        [DisplayName("Show confirmations")]
        [Category("Options")]
        bool Confirm { get; set; }
        [DefaultValue(false)]
        bool Silent { get; set; }
        [Browsable(false)]
        List<string> OtherParameters { get; set; }
# A plugins that shows a custom dialog
#### <a class="anchor" id="bkmrk-"></a>Creating a plugin that displays a custom dialog
To run this example you must first create a C# project that refrecnes FTC.SDKInterface.dll, Feat.UIComposition.dll and Feat.Core.dll. The resulting dll from your project (along with any non .NET dependecies) must be placed in the Plugins directory in the FTC install location.
##### <a class="anchor" id="bkmrk--0"></a>The Plugin class.
 public class PluginWithMenuAndDialogPlugin : IPluginService
   get { return "A plugin with a menu item and dialog"; }
The initliaze method will register a menu command and a custom dialog Registering Commands: To register a command first an interface that derives from ICommandContainer must be created. The interface will contain properties for each of the commands that will be registered. The interface will be implemented internally by Scene Composer. The plugin can then register the commands using the UICommandManager service. This can be done either directly or using the helper class CommandDefinitionCollection that simplifies the registering of multiple commands.
The command can be invoked from code, (see other more complex examples for a demonstration), or can be displayed in the menu or used as a shortcut. This is done by attaching metadata to the command, as displayed in the example.
   var uiDefManager = unityContainer.Resolve<UIDefinitionManager>();
   //Creates a collection of ui element definitions.
   var uiElementCollection = new UIDefinitionCollection()
       new DialogDefinition<ICustomDialogViewModel, CustomDialogViewModel, ICustomDialogView, CustomDialogView>()
   // We register the elements of the collection with the UIDefinitionManager
   uiElementCollection.RegisterAll(uiDefManager);
   // We create the command collection and add the command definitions.
   var cmdCollection = new CommandDefinitionCollection<IPluginCommands>()
         c => c.ContextCommand,
         new ManagedCommand<IBitmap>()
            ExecuteHandler = o=>
            Metadata = new MetadataCollection()
               new ContextMenuOption()
                   MenuPath = new MenuPath() { "Here" },
                   PanelViewModel = typeof(ITreeViewModel<>)
            new AutoInvalidateOnSelectionInterface<ISelectedSolution>()
         c=>c.ShowDialogCommand,
         new ManagedCommand()
           ExecuteHandler = (o)=>
             var dlgSrv = unityContainer.Resolve<IDialogSvc>();
             var dialogVM = unityContainer.Resolve<ICustomDialogViewModel>();
             dialogVM.Message = "Custom Dialog";
             if (dlgSrv.ShowDialog(dialogVM) == true)
               dlgSrv.ShowMessageBox(dialogVM.Message);
             new MainMenuOption()
               MenuPath = new MenuPath() { MenuConstants.File_2, "My Menu Option", 350 },
             new ToolTip("Invokes a custom dialog from a plugin"),
             new KeyShortcut() { Key = Key.B, Modifiers= ModifierKeys.Control | ModifierKeys.Shift },
   cmdCollection.RegisterAll(unityContainer.Resolve<UICommandManager>());
##### <a class="anchor" id="bkmrk--2"></a>The dialog window
This custom dialog will contain a button that will exacute a command to display a messagebox.
 this.ShowMessageBox = new ManagedCommand()
   ExecuteHandler = o =>
   container.Resolve<IDialogSvc>().ShowMessageBox
   "Message box from a plugin",
   "Message box title",
   MessageBoxButton.OK,
   MessageBoxImage.Exclamation
The full code for the example:
##### <a class="anchor" id="bkmrk--3"></a>CustomUIConfigPlugin.cs
  using System;
  using System.Linq;
  using System.Text;
  using FTC.SDKInterface.Selections;
  using Feat.UIComposition.Common;
  using Feat.UIComposition.Paneling;
  using UIPlugins.PluginWithMenuAndDialog.CustomDialog;
  using Feat.UIComposition.Dialogs;
  using Feat.UIComposition.Shortcuts;
  using System.Windows.Input;
  using Feat.CAL.Services;
  using Feat.UIComposition.ContextMenus;
  using Feat.Core;
  using FTC.SDKInterface.Solution;
  namespace UIPlugins.PluginWithMenuAndDialog
     /// <summary>
     /// This is an example of a plugin that registers a command and displays a custom dialog and message boxes
     /// </summary>
        public string Name
        /// <summary>
        /// The initialization method has the role of registering with Scene composer different items that the plugin will use
        /// </summary>
        /// In this example the initliaze method will register a menu command and a custom dialog
        /// Registering Commands:
        /// To register a command first an interface that derives from ICommandContainer must be created.
        /// The interface will contain properties for each of the commands that will be registered.
        /// The interface will be implemented internally by Scene Composer.
        /// The plugin can then register the commands the UICommandManager service. This can be done either
        /// directly or using the helper class CommandDefinitionCollection that simplifies the registering of multiple
        /// commands. \n
        /// The command can be invoked from code, (see other more complex examples for a demonstration),
        /// or can be displayed in the menu or used as a shortcut. This is done by attaching metadata to the command,
        /// as displayed in the example.
        /// <param name="unityContainer"></param>
           // In this case we just register a dialog.
           // A ui element has 4 elements :
           // - a view model interface
           // - a view model class implementation
           // - a view interface
           // - a view class implementation
                       //unityContainer.Resolve<FTC.SDKInterface.Selections.ISelectedScene>().Value = o as FTC.SDKInterface.Solution.IScene,
                 // We specify the command for which we are registering an implementation,
                 // The type of c will be inferred to be IPluginCommands, so we don't have to specify it.
                       // Invokes a dialog that was previously registered with the UIDefinitionManager.
                       // We first create the viewmodel for the dialog
                       // We configure the view model properties
                       // We show the dialog. The dialog window will be constructed based on the information registered in the
                       // UIDefinitionManager service.
                       // The main menu option to be created.
                       // The menu path is specifies the location where the menu should be displayed.
                       // The menu constant class contains the main menu definitions used by scene composer.
                       // The plugin can an other main menu options too.
                       // The tokens of the path can be specified either with commas, or using menu path syntax
                       // The each token of a path can be followed by an integer that represents the order of the item
                       // in the menu. The option present in the scene composer menu, have order indexes that increase by 100,
                       // so plugins can add items in between the existing items
                       // A menu can be devided in several groups, in the example below, the item is added in the second group of the file menu.
                       // Specifies a tooltip for the command, used for the menu items and the key shortcuts
                       //Specifies a shortcut key for the command.
           // We register the commands.
     /// <summary>
     /// The interface that contains the command definitions.
     /// </summary>
     /// The main role of this interface is to uniquely identify the command and to provide an easy way to access the commands from code
     /// No implementation of this interface is required, Scene COmposer will generate a concrete class if needed.
     public interface IPluginCommands : ICommandContainer
        ManagedCommand ShowDialogCommand { get; }
        ManagedCommand<IBitmap> ContextCommand { get; }
##### <a class="anchor" id="bkmrk--4"></a>ICustomDialogViewModel.cs
  using System;
  using Feat.Core;
  namespace UIPlugins.PluginWithMenuAndDialog.CustomDialog
     /// <summary>
     /// The dialog view model interface. This interface can be used to exchange information between the dialog caller and the dialog viewmodel.
     /// </summary>
     public interface ICustomDialogViewModel
        string Message { get; set; }
##### <a class="anchor" id="bkmrk--5"></a>ICustomDialogView.cs
  using System;
  using System.Linq;
  using System.Text;
  using Feat.Core;
     /// <summary>
     /// The interface for the dialog view. It contains no methods as the view does not communicate directly with anyone else.
     /// </summary>
     public interface ICustomDialogView : IDialogView
##### <a class="anchor" id="bkmrk--6"></a>CustomDialogViewModel.cs
  using System;
  using System.Linq;
  using System.Text;
  using System.IO;
  using System.Windows;
  using Feat.Core;
     class CustomDialogViewModel : ICustomDialogViewModel
        public CustomDialogViewModel(IUnityContainer container)
           // We create a simple command to demo using a Scene Composer message box
           // This is the way to show message box so that it will conform to the Scene Composer look and feel
        /// <summary>
        /// The command for showing a dialog box, that will be bound to the view.
        /// </summary>
        public ICommand ShowMessageBox { get; set; }
        /// <summary>
        /// The message that will be retuned by the viewmodel.
        /// </summary>
        public string Message { get; set; }
##### <a class="anchor" id="bkmrk--7"></a>CustomDialogView.xaml
     The actual UI for the view. Most of the look and feel for the application is inherited by the diloag from the scene composer application
     The dialog window must however specify the Style property to ensure consistent look and feel, as seen in the tag below.
     The DialogWindow style resource is defined within Scene Composer
  <ui:DialogWindow
      x:Class="UIPlugins.PluginWithMenuAndDialog.CustomDialog.CustomDialogView"
      xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
      xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
      xmlns:ui="clr-namespace:Feat.Core;assembly=Feat.Core"
      Title="Plugin dialog"
      Style="{DynamicResource DialogWindow}" >
     <StackPanel Margin="15">
        <Label Content="This is a custom dialog defined in a plugin"></Label>
        <StackPanel>
           <Label Content="Message:"></Label>
           <!--We use databiding to edit the MessageProperty-->
           <TextBox Text="{Binding Message}"></TextBox>
        </StackPanel>
        <!--We  use databinding to assign the ShowMessageBox command to the button-->
        <Button Command="{Binding ShowMessageBox}" Content="Show message Box" Margin="0,30,0,10" Width="200"></Button>
        <StackPanel Orientation="Horizontal" Margin="10">
           <Button Click="OnOk" Margin="10" Content="OK"></Button>
           <Button Click="OnCancel" Margin="10" Content="Cancel"></Button>
        </StackPanel>
     </StackPanel>
  </ui:DialogWindow>
# A plugins that defines a custom menu
#### <a class="anchor" id="bkmrk-"></a>Creating a plugin that displays a custom menu
  public class CustomMenuPlugin : IPluginService
   get { return "Custom Menu Definition"; }
    get { return "A plugin that defines a custom menu"; }
   get { return "1.0"; }
     //register the menu config interface
     var loader = unityContainer.Resolve<IConfigurationManager>().RegisterConfigurationInterface<IMenuPluginConfig>();
##### <a class="anchor" id="bkmrk--2"></a>Config and commands interfaces
We will need to provide an interface derived from IConfiguration and an interface derived from ICommandContainer that defines the available commands.
 public interface IMenuPluginConfig : IConfiguration
   ObservableCollection<string> Data { get; set; }
 public interface ICustomPluginCommands : ICommandContainer
   ManagedCommand AddItem { get; }
   ManagedCommand RemoveItem { get; }
Then in the Initialize method:
Register the menu config interface
Register the menu commands
  var cmdCollection = new CommandDefinitionCollection<ICustomPluginCommands>()
      c=>c.AddItem,
            var data = loader.Instance.Data;
            data.Add("Item " + data.Count);
               MenuPath = new MenuPath() { MenuConstants.File_1, "Items", "Add" },
      c=>c.RemoveItem,
         CanExecuteHandler = o=> loader.Instance.Data.Any(),
            data.RemoveAt(0);
               MenuPath = new MenuPath() { MenuConstants.File_1, "Items", "Remove" },
And register a custom menu definition to hold the item list
  var menuDefMgr = unityContainer.Resolve<MenuDefinitionManager>();
  menuDefMgr.RegisterMenuDefinition(new CustomMenuDefinition()
     MenuPath = new MenuPath() { MenuConstants.File_1, "Items", "RegItems" },
  loader.Instance.Data.CollectionChanged += Data_CollectionChanged;
##### <a class="anchor" id="bkmrk--3"></a>CustomMenuPlugin.cs
using System;
using System.Linq;
using System.Text;
using System.Collections.ObjectModel;
namespace UIPlugins.CustomMenu
     public string Name
        get { return this.Description; }
     public FTC.SDKInterface.Services.IUnityContainer UnityContainer { get; set; }
     public void Initialize(FTC.SDKInterface.Services.IUnityContainer unityContainer)
        this.UnityContainer = unityContainer;
              c=>c.AddItem,
              c=>c.RemoveItem,
                    data.RemoveAt(0);
     void Data_CollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e)
        var cmdContainer = this.UnityContainer.Resolve<UICommandManager>().GetCommandContainer<ICustomPluginCommands>();
        cmdContainer.RemoveItem.RaiseCanExecuteChanged();
     void loader_ConfigLoaded(object sender, ConfigLoadedEventArgs<IMenuPluginConfig> e)
           e.Instance.Data = new ObservableCollection<string>();
##### <a class="anchor" id="bkmrk--4"></a>CustomMenuDefintion.cs
using System;
using System.Linq;
using System.Text;
using System.Windows.Controls;
using Feat.Utils;
  class CustomMenuDefinition : MenuDefinitionBase
     protected override IMenuItemManager CreateMenuItemManger(MenuManager menuManger)
        return new CustomMenuManager(this);
     public override string UniqueName
        get { return this.GetType().AssemblyQualifiedName + this.MenuPath; }
  class CustomMenuManager : IMenuItemManager
     public ObservableCollection<string> items;
     private IDialogSvc dialogSvc;
     public CustomMenuDefinition Definition { get; set; }
     public CustomMenuManager(CustomMenuDefinition cmDef)
        this.Definition = cmDef;
        this.dialogSvc = this.Definition.UnityContainer.Resolve<IDialogSvc>();
        this.items = this.Definition.UnityContainer.Resolve<IConfigurationManager>().
           GetConfiguration<IMenuPluginConfig>().Data;
        items.CollectionChanged += items_CollectionChanged;
     void items_CollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e)
        this.Invalidate();
     MenuItem rootMenuItem;
     public void Attach(MenuManager menuMgr, ItemsControl parentMenuItem, object startingSibling)
        this.rootMenuItem = new MenuItem()
           Header = "ItemList"
        parentMenuItem.Items.Add(rootMenuItem);
        this.Invalidate();
     public bool IsItemVisible
        get
           return this.items.Any();
     public event EventHandler HasItemsChanged;
     public void Invalidate()
        this.rootMenuItem.Items.Clear();
        items.
           Select(s => new MenuItem()
              Header = s,
              Command = new ManagedCommand()
                    this.dialogSvc.ShowMessageBox(s, s, MessageBoxButton.OK, MessageBoxImage.Information)
           ForEach(i => this.rootMenuItem.Items.Add(i));
        if (this.HasItemsChanged != null)
           this.HasItemsChanged(this, EventArgs.Empty);
# A simple plugin that consumes events
#### <a class="anchor" id="bkmrk-"></a>Creating a plugin that consumes events
To run this example you must first create a C# project that refrecnes FTC.SDKInterface.dll and Feat.Core.dll. The resulting dll from your project (along with any non .NET dependecies) must be placed in the Plugins directory in the FTC install location.
The first step is to create a class that implements the IEventListener interface. This is the type that will be instantiated by Scene Composer.
 public class SimpleEventsConsumer : IEventListener
   get { return "SC event consumer plugin"; }
    get { return "A plugin that consumes SC events and shows a message box on each event"; }
   get { return "1.1.0"; }
    //resolve the IDialogSvc interface. We will use it to show simple message boxes.
   dlgSvc = unityContainer.Resolve<IDialogSvc>();
##### <a class="anchor" id="bkmrk--2"></a>Specifying what events should be handled by the plugin.
We implement the EventsToSubscribe property of the IEventListener interface. This property specifies a set of events that Scene Composer should pass to the plugin.
 public EventId EventsToSubscribe
   get { return EventId.AppShutdown | EventId.AssetGeneration | EventId.ImportFinished | EventId.SolutionChanged; }
##### <a class="anchor" id="bkmrk--3"></a>Implementing the event handlers of IEventListener
Next we implement event handler methods.
 public void OnAssetGeneration(string assetFile, bool isTargetAsset, OperationStatus status)
   ShowMessage(String.Format("Asset generation for '{0}'  {1}.", assetFile, status));
 public void OnImportFinished()
   ShowMessage("Import finished.");
 public void OnShutdown()
   ShowMessage("App shutting down.");
 public void OnSolutionChanged(FTC.SDKInterface.Solution.ISolution solution)
   ShowMessage("Solution changed!");
The ShowMessage method uses IDialogSvc to show a messagebox.
 private void ShowMessage (string message)
   Application.Current.Dispatcher.BeginInvoke(new Action( () =>
     dlgSvc.ShowMessageBox(message, "EventsPlugin");
   }), null );
##### <a class="anchor" id="bkmrk--4"></a>SimpleEventsConsumer.cs
 using System;
 using System.Linq;
 using System.Text;
 using System.Threading.Tasks;
 namespace SCEventsPlugin
      private IDialogSvc dlgSvc;
      private void ShowMessage(string message)
         Application.Current.Dispatcher.BeginInvoke(new Action(() =>
         }), null);
         get { return new int[0]; }
         //resolve the IDialogSvc interface. We will use it to show a message boxes.
      public string Name
