# Candera 3.6
To keep backwards compatibility for any interface change in the public API the old interface has been kept and marked as deprecated. The deprecated interfaces will be removed in future versions. Compiler warnings will be generated when using a deprecated interface through the usage of Candera Macro CANDERA\_DEPRECATED\_3\_6\_0.
Added flags:
<div class="contents" id="bkmrk-name-description-pos"><div class="contents"><div class="textblock"><table border="1" cellpadding="5" cellspacing="0" style="width: 100%;"><tbody><tr bgcolor="#d4d4d4"><td class="align-center" style="width: 44.7442%;">**Name**</td><td class="align-center" style="width: 44.131%;">**Description**</td><td class="align-center" style="width: 11.1248%;">**Possible values**</td></tr><tr><td style="width: 44.7442%;">CANDERA\_TEXTENGINE\_NATIVE\_LINEHEIGHT\_ENABLED</td><td style="width: 44.131%;">Enables the native line height metrics of the font engine. If disabled then 120% of EM size is applied as line height which is compatible with Adobe.</td><td style="width: 11.1248%;">ON/OFF</td></tr></tbody></table>
</div></div></div>
# Candera Engine 2D
#### Node2d GetComputedBoundingRectangle, IsInsideBoundingRectangle, IsPickIntersectingBoundingRectangle and GetEffectiveBoundingRectangle interface extended
The method 'virtual void Node2d::GetComputedBoundingRectangle([Rectangle](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_rectangle.html "Represents a rectangle.")&amp; boundingRectangle, bool ignoreInvisible = false) const' has been extended by the additional parameter ignoreInvisible. The default value of this parameter is false for full usage backwards compatibility. If the parameter is set to true only visible parts of the scene will be considered. This also means that clipped areas are not considered for picking and/or bounding box calculations. As a consequence it is now possible to pick only visible parts of the scene.
</div></div></div>#### Pivot point for Transformable2D
New methods to [Transformable2D](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_transformable2_d.html "Defines common methods for manipulating node and texture transformations in local coordinate space (o...") have been added that allow to manipulate the real pivot point. Those are [Transformable2D::SetPivotPoint](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_transformable2_d.html#a99ea052896f7f67537676a574631fffa) and [Transformable2D::GetPivotPoint](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_transformable2_d.html#a4324d5a75b09667adb6ef56c91def551) .
# Candera Engine 3D
#### Generic Transform is Optional
The Property "Generic Transform" of a 3D [Node](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_node.html "The class Node is an abstract base class for all scene graph nodes. Each Node defines a local coordin...") became optional. The reason for that is to have as few matrix multipilcations as possible which saves performance. Further wise Generic Transforms are only used for special needs.
New methods to [Transformable](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_transformable.html "Defines common methods for manipulating node and texture transformations in local coordinate space (o...") have been added that allow to manipulate the real pivot point. Those are [Transformable::SetPivotPoint](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_transformable.html#a7a885bce1ab6cff4e26882759d1377ae) and [Transformable::GetPivotPoint](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_transformable.html#a8e7479a1a7cbb992d901e9db8454f550) .
# Transitions
#### Sequential Transitions - Extended Hint Constructor
The constructor for Transition Hints has been extended in order to reflect the newly added ability to execute Transitions in a sequential manner.
The added parameters are:
    const <a class="code" href="http://dev.doc.cgistudio.at/APILINK/class_feat_std_1_1_optional.html">FeatStd::Optional<FragmentStrategy></a>& activationStrategy
    const <a class="code" href="http://dev.doc.cgistudio.at/APILINK/class_feat_std_1_1_optional.html">FeatStd::Optional<FragmentStrategy></a>& deactivationStrategy
    const <a class="code" href="http://dev.doc.cgistudio.at/APILINK/class_feat_std_1_1_optional.html">FeatStd::Optional<Float></a>& activationDelay
    const <a class="code" href="http://dev.doc.cgistudio.at/APILINK/class_feat_std_1_1_optional.html">FeatStd::Optional<Float></a>& deactivationDelay
FragmentStrategy is a new enum type consisting of:
<div class="contents" id="bkmrk-normal-early-late"><div class="contents"><div class="textblock">
- Normal
- Early
- Late
</div></div></div>#### Transition Rules - Check if Rule is Bidirectional
The Rule class has a new method called bool Rule::IsBidirectional() const, which returns, whether the Transition Rule is set to be bidirectional or not.
# Textengine
#### AssetFontStore support for Freetype streams
[AssetFontStore](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_asset_font_store.html "implements a font store for the asset library this is the default font store Candera will use to retr...") is extended to support two font load strategies:
<div class="contents" id="bkmrk-assetfontstore%3A%3Aload"><div class="contents"><div class="textblock">
- [AssetFontStore::LoadStrategySelector::PreloadStrategy](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_asset_font_store_1_1_load_strategy_selector.html#a3c06cdd0709312d8b0ac60035c9a3b62aad010b9a2098e4e40ff1f0be8f31ba4b "Load the entire font data into memory if it is not already in a direct addressable asset repository...") (the old behavior before the extension): entire fonts are loaded into memory once and font data is accessed from there by Text Engine.
- [AssetFontStore::LoadStrategySelector::OnRequestLoadStrategy](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_asset_font_store_1_1_load_strategy_selector.html#a3c06cdd0709312d8b0ac60035c9a3b62abddf5927381d24532b5a902fda7d33f3 "Do not load anything in memory, but read/copy data into smaller temporary buffers as requested by Fre...") (new behavior, selectable through a strategy selector): small font portions are streamed directly from the asset repository when Freetype (or indirectly Harfbuzz) needs them.
</div></div></div>Use [DefaultLoadStrategySelector::SetDefaultFontLoadStrategy](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_default_load_strategy_selector.html#a340dda8ac0dfb937a3d77d68817bfd48) to select one of these load strategies. Use [DefaultLoadStrategySelector::SetDefaultFontLoadStrategyExceptionList](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_default_load_strategy_selector.html#ac9e45f0d804d98677032b463b50b3513) to exclude a list of fonts from the selected font load strategy.
Example:
    // Load fonts with OnRequestLoadStrategy
    selector.SetDefaultFontLoadStrategy(<a class="code" href="http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_asset_font_store_1_1_load_strategy_selector.html#a3c06cdd0709312d8b0ac60035c9a3b62abddf5927381d24532b5a902fda7d33f3" title="Do not load anything in memory, but read/copy data into smaller temporary buffers as requested by Fre...">Candera::AssetFontStore::LoadStrategySelector::OnRequestLoadStrategy</a>);
    // "Bitstream Vera Sans" font shall be loaded with PreloadStrategy:
    const Char* g_fontName[2] = { "ConstructionKit##ConstructionKit#Resources#Fonts#Bitstream Vera Sans", 0 };
    selector.SetDefaultFontLoadStrategyExceptionList(g_fontName);
    fontStore.SetLoadStrategySelector(&selector);
[Courier](http://dev.doc.cgistudio.at/APILINK/namespace_courier.html) applications can use [Courier::ViewHandler::SetFontStoreProviderCallback](http://dev.doc.cgistudio.at/APILINK/class_courier_1_1_view_handler.html#a7747f74f80b57fd376b13f942d927009) to provide specific settings for the [Candera::AssetFontStore](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_asset_font_store.html "implements a font store for the asset library this is the default font store Candera will use to retr...") in use.
</div></div></div>#### Support of Monotype's WorldType-Shaper
[Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "&#91;DataBinding&#95;RefTypeSample&#93;") supports the WorldType-Shaper of Monotype now. The integration is done to support the font engine 'iType'. With this release complex texts can be shaped. The behavior is similar to HarfBuzz with the difference of a huge performance boost. WT-Shaper may have a higher memory consumtion as a trade-off to performance. The implementation concept is aligned with HarfBuzz to support a flexible exchangeability.
With this the default shaper of iType switches from ComplexScript to WT-Shaper. The corresponding CMake flag CANDERA\_TEXTSHAPER has been extended by the entry WorldType-Shaper.
