# CGI Studio 3.3.3
# Candera V3.3.3
#### Release Info
<div class="contents" id="bkmrk-release-date%3A-march-"><div class="contents"><div class="textblock">
- Release Date: March 2017
</div></div></div>#### Deprecated Interfaces
To keep backwards compatibility for any interface change in the public API the old interface has been kept and marked as deprecated. The deprecated interfaces will be removed in future versions. Compiler warnings will be generated when using a deprecated interface through the usage of [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "&#91;DataBinding&#95;RefTypeSample&#93;") Macro CANDERA\_DEPRECATED\_3\_3\_3.
#### Interface Changes
No feature changes for 3.3.3 Release.
# Courier V3.3.3
#### Release Info
</div></div></div>#### Changes
# FeatStd V3.3.3
#### Release Info
</div></div></div>#### Interface Changes
# SceneComposer V3.3.3
#### Display Solution Controls as Vertical List
The solution controls are displayed as a vertical list instead of horizontal icon list (Mantis 8629).
<div class="contents" id="bkmrk-see-also%3A-3d-toolbox"><div class="contents"><div class="textblock"><dl class="see"><dt>**See also:**</dt><dd>
- <span style="color: rgb(230, 126, 35);">[3D Toolbox](https://doc316en.candera.eu/link/130#bkmrk-3d-toolbox)</span> in SceneComposer User Manual &amp;
- <span style="color: rgb(230, 126, 35);">[2D Toolbox](https://doc316en.candera.eu/link/147#bkmrk-2d-toolbox)</span> in SceneComposer User Manual
</dd></dl>---
</div></div></div>#### FTCCmd Rules for Operations on Solutions Opened in SceneComposer
The following rules are applied when FTCCmd is used on a solution which is already loaded in SceneComposer:
<div class="contents" id="bkmrk-the-info-with-conver"><div class="contents"><div class="textblock">
- the Info with Convert No option, Generate with Convert No option and ExportScl commands will not attempt locking;
- the Info with Convert Yes option, Generate with Convert Yes option and Import commands will attempt locking and fail if solution is already loaded in SceneComposer (Mantis 8499).
- <span style="color: rgb(230, 126, 35);">[FTC Command](https://doc316en.candera.eu/link/178#bkmrk-page-title)</span> in SceneComposer User Manual
</dd></dl>---
</div></div></div>#### Shader Compiler Plugin for Intel Apollo Lake
A new shader compiler plugin was created for Intel Apollo Lake platform. In this way it is possible to optionally compile the shaders (binary shader) for the desired target (Mantis 8405).
