# SceneComposer V3.3.3
#### Display Solution Controls as Vertical List
The solution controls are displayed as a vertical list instead of horizontal icon list (Mantis 8629).
<div class="contents" id="bkmrk-see-also%3A-3d-toolbox"><div class="contents"><div class="textblock"><dl class="see"><dt>**See also:**</dt><dd>
- <span style="color: rgb(230, 126, 35);">[3D Toolbox](https://doc316en.candera.eu/link/130#bkmrk-3d-toolbox)</span> in SceneComposer User Manual &amp;
- <span style="color: rgb(230, 126, 35);">[2D Toolbox](https://doc316en.candera.eu/link/147#bkmrk-2d-toolbox)</span> in SceneComposer User Manual
</dd></dl>---
</div></div></div>#### FTCCmd Rules for Operations on Solutions Opened in SceneComposer
The following rules are applied when FTCCmd is used on a solution which is already loaded in SceneComposer:
<div class="contents" id="bkmrk-the-info-with-conver"><div class="contents"><div class="textblock">
- the Info with Convert No option, Generate with Convert No option and ExportScl commands will not attempt locking;
- the Info with Convert Yes option, Generate with Convert Yes option and Import commands will attempt locking and fail if solution is already loaded in SceneComposer (Mantis 8499).
- <span style="color: rgb(230, 126, 35);">[FTC Command](https://doc316en.candera.eu/link/178#bkmrk-page-title)</span> in SceneComposer User Manual
</dd></dl>---
</div></div></div>#### Shader Compiler Plugin for Intel Apollo Lake
A new shader compiler plugin was created for Intel Apollo Lake platform. In this way it is possible to optionally compile the shaders (binary shader) for the desired target (Mantis 8405).
