# CGI Studio 3.3.2
# Candera V3.3.2
#### Release Info
<div class="contents" id="bkmrk-release-date%3A-march-"><div class="contents"><div class="textblock">
- Release Date: March 2017
</div></div></div>#### Deprecated Interfaces
To keep backwards compatibility for any interface change in the public API the old interface has been kept and marked as deprecated. The deprecated interfaces will be removed in future versions. Compiler warnings will be generated when using a deprecated interface through the usage of [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "&#91;DataBinding&#95;RefTypeSample&#93;") Macro CANDERA\_DEPRECATED\_3\_3\_2.
#### Interface Changes
No feature changes for 3.3.2 Release.
# Courier V3.3.2
#### Release Info
</div></div></div>#### Changes
# FeatStd V3.3.2
#### Release Info
</div></div></div>#### Interface Changes
# Analyzer V3.3.2
#### Release Info
</div></div></div>#### Feature Changes
# SceneComposer V3.3.2
#### Layout Borders
The borders of the grid cells can be visualized in SceneComposer scene editor. The border of every cell of the layouter will be visible as a yellow line. This border is visible if the group is selected or if just one single cell is selected.
Two different secondary borders - the bounding box of the parent node, and the bounding box of the effective node - will be visible, marked with blue, if some values are set (Mantis 8367).
<div class="contents" id="bkmrk-see-also%3A-cgi-studio"><div class="contents"><div class="textblock"><dl class="see"><dt>**See also:**</dt><dd>
- <span style="color: rgb(230, 126, 35);">[CGI Studio 3.3.2 - What's New](https://doc316en.candera.eu/link/183#bkmrk-cgi-studio-3.3.2---w)</span> in SceneComposer User Manual
- <span style="color: rgb(230, 126, 35);">[General Layout Properties](https://doc316en.candera.eu/link/152#bkmrk-general-layout-prope-0)</span> in SceneComposer User Manual
</dd></dl>---
</div></div></div>#### No Displays in "Shareable Component Library" (SCL)
Since this version on, "shareable component library" (SCL) are not allowed to contain any display. The following two scenarios can result:
<div class="contents" id="bkmrk-if-an-already-create"><div class="contents"><div class="textblock">
- If an already created solution does contain any display, the user will be noticed through a specific dialogue.
- If an older imported/converted solution already contains a .scl file with displays, the error will be showed in the Problems panel. In this way, the user will be noticed and will be allowed to correct this situation.
- <span style="color: rgb(230, 126, 35);">[Reusable Solution Libraries](https://doc316en.candera.eu/link/47#bkmrk-page-title)</span> in SceneComposer User Manual
</dd></dl>---
<dl class="see"></dl></div></div></div>
