# SceneComposer V3.3.2
#### Layout Borders
The borders of the grid cells can be visualized in SceneComposer scene editor. The border of every cell of the layouter will be visible as a yellow line. This border is visible if the group is selected or if just one single cell is selected.
Two different secondary borders - the bounding box of the parent node, and the bounding box of the effective node - will be visible, marked with blue, if some values are set (Mantis 8367).
<div class="contents" id="bkmrk-see-also%3A-cgi-studio"><div class="contents"><div class="textblock"><dl class="see"><dt>**See also:**</dt><dd>
- <span style="color: rgb(230, 126, 35);">[CGI Studio 3.3.2 - What's New](https://doc316en.candera.eu/link/183#bkmrk-cgi-studio-3.3.2---w)</span> in SceneComposer User Manual
- <span style="color: rgb(230, 126, 35);">[General Layout Properties](https://doc316en.candera.eu/link/152#bkmrk-general-layout-prope-0)</span> in SceneComposer User Manual
</dd></dl>---
</div></div></div>#### No Displays in "Shareable Component Library" (SCL)
Since this version on, "shareable component library" (SCL) are not allowed to contain any display. The following two scenarios can result:
<div class="contents" id="bkmrk-if-an-already-create"><div class="contents"><div class="textblock">
- If an already created solution does contain any display, the user will be noticed through a specific dialogue.
- If an older imported/converted solution already contains a .scl file with displays, the error will be showed in the Problems panel. In this way, the user will be noticed and will be allowed to correct this situation.
- <span style="color: rgb(230, 126, 35);">[Reusable Solution Libraries](https://doc316en.candera.eu/link/47#bkmrk-page-title)</span> in SceneComposer User Manual
</dd></dl>---
<dl class="see"></dl></div></div></div>
