# FeatStd V3.3.1
# Hash Table
This version introduces a hash table container. A hash table is a data structure used to implement an associative array, a structure that can map keys to values. A hash table uses a hash function to compute an index into an array of buckets or slots, from which the desired value can be found.
# Random number generator
This version introduces a deterministic random number generator. [Random](http://dev.doc.cgistudio.at/APILINK/class_feat_std_1_1_random.html "The Random class generates random numbers deterministically. It is based on the &quot;Mother-of-all&quot; gener...") number generation is the generation of a sequence of numbers or symbols that cannot be reasonably predicted better than by a random chance.
# AsyncRequests
AsyncRequests were moved from internal namespace to FeatStd.
# Floor and FMod
Two functions were added: Floor returns the greatest integer less than or equal to the passed value. For an integer x and a positive integer y, FMod gives the value of the remainder when x is divided by y.
# FeatStd Monitor
Changes were made on the FeatStd part of Monitor to support the Feature: thread safe performance recording. See [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "&#91;DataBinding&#95;RefTypeSample&#93;") Monitoring for further details.
