# Analyzer V3.2.1
# Scene Analyzer
#### Loading Performance Logs
A streamed performance log can be loaded after pressing pause now.
Opening performance logs of older versions is supported now.
</div></div></div>#### Dashboard functionality
The dashboard can load more than the default value recorders (CpuLoad, GpuLoad, MemoryUsage) now. Drag'n'Drop a graph to show multiple value-recorders in one graph is possible now.
Graphs with no content are no longer shown.
# Communication
Stabilized the connection and solved crashes (hang up) when pressing stop button.
Requests for communication port uses own scheduler now. This results in better reactivity and a more stabilized connection.
Adaptions made to support non-blocking connection setup.
<div class="contents" id="bkmrk-see-also%3A-featstd-mo"><div class="textblock"><dl class="see"><dt>**See also:**</dt><dd><span style="color: rgb(230, 126, 35);">[FeatStd Monitor](https://doc316en.candera.eu/link/886#bkmrk-page-title)</span></dd></dl></div></div>---
