# CGI Studio 3.15.1
Release Date: April 2025
# General 3.15.1
This page describes general updates that were made to CGI Studio version 3.15.1.
#### Scene Composer
- Improved import procedures
- General performance improvements
#### Sample Solution
- Updated GettingStartedControls Solution
- Updated Post Processing Solution
- Updated 3D Effects Solution
#### New CMake Environment
Added CMake flags to customize Control behaviors
#### Documentation
Added [<span style="color:rgb(230,126,35);">"Candera Graphics Programming"</span>](https://doc316en.candera.eu/books/target-setup-for-traveo2/chapter/candera-graphics-programming-best-practices-for-traveo-ii) as a best practice for Traveo2.
#### Professional Edition
Improved CGI Studio Professional Edition installer and easier user onboarding with supported platforms.
# Candera 3.15.1
#### Candera Engine
- [Dirty Area Management](https://doc316en.candera.eu/books/courier/page/dirty-area-management "Dirty Area Management") support added
- Improved performance for several rendering related functions
- Switched from zlib to miniz to reduce code size
- Improved touch interaction handling
- <span>Bitmap Stride information is automatically set on supported platforms</span>
# Controls 3.15.1
#### Core Controls
Added a new set of Core Controls
- CoreDial
- CoreText
- CoreButton
- CoreDigitalClock
- CoreProgressBar
- CoreTextButton
- CoreCheckBox
- CoreToggleButton
- CoreRadioButton
- CoreTextValue
- CoreSlider
- CoreScrollView
- CoreMultiStateButton
# Behavior 3.15.1
#### Image and Video Decoding
- JPEG Decorder: Traveo II behavior to allow usage of the platforms JPEG decoder
#### Value Processing
- Value Generator behavior added
# Scene Composer 3.15.1
#### New Feature
- Dirty Area Management added
- Bitmap stride information can be configured on asset export
#### Import feature improvements
- Added new FBX import options
- Improved glTF import
- Smart Importer
    - Added "Freehand dialog background color" to the Smart Importer preferences
    - Adjusted default values for pivot points
#### Other improvements
- Performance improvements
- Improved connection handling to target when using Text Size Report
- Other minor modifications
#### Solutions
- Getting Started Controls extension to showcase Core Controls
- Upgraded Post Processing Sample
- Improved 3D Effects Solution
