# SceneComposer V3.0.1
#### Shader Warnings
Shader warnings generation was activated (deactivated in previous version, 3.0.0).
**See also:**
<div class="contents" id="bkmrk-shader-consistency-c"><div class="contents"><div class="textblock">
- <span style="color: rgb(230, 126, 35);">[Shader Consistency Checker](https://doc316en.candera.eu/link/146#bkmrk-shader-consistency-c)</span> in SceneComposer User Manual
</div></div></div>#### Shader Consistency Checker
**See also:**
<div class="contents" id="bkmrk-shader-consistency-c-2"><div class="textblock">
</div></div>---
