# Building Candera
# Select Features
<div class="contents" id="bkmrk-cmake-feature-switch"><div class="contents"><div class="textblock"><dl class="warning"><dd><p class="callout warning">CMake feature switches have been renamed for V3.x releases, see <span style="color: rgb(230, 126, 35);">[Change Log](https://doc316en.candera.eu/shelves/6-change-log)</span></p>
</dd></dl></div></div></div>#### <a class="anchor" id="bkmrk-"></a>Select Candera Features
Build settings for the [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") Engine are specified by the following CMake variables:
<div class="contents" id="bkmrk-name-description-pos"><div class="contents"><div class="textblock"><table border="1" cellpadding="5" cellspacing="0" style="border-collapse: collapse; width: 800px; border-width: 1px; border-spacing: 0px;" width="1150"><tbody><tr bgcolor="#d4d4d4"><th style="border-width: 1px; padding: 5px;">**Name**</th><th style="border-width: 1px; padding: 5px;">**Description**</th><th style="border-width: 1px; padding: 5px;">**Possible values**</th></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_2D\_ENABLED</td><td style="border-width: 1px; padding: 5px;">Enables [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") engine's 2D elements.
If both 2D and 3D are enabled, the solution will contain both CanderaEngine2D and CanderaEngine3D subprojects.</td><td style="border-width: 1px; padding: 5px;">ON/OFF</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_LAYOUT\_ENABLED</td><td style="border-width: 1px; padding: 5px;">Enables [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") 2D dynamic layout.
If disabled, the whole code for dynamic layout is removed.</td><td style="border-width: 1px; padding: 5px;">ON/OFF</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_LAYOUT\_CLIPPING\_ENABLED</td><td style="border-width: 1px; padding: 5px;">Enables clipping of [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") 2D dynamic layout.
If enabled, the render area of a render node is clipped to the layout area.</td><td style="border-width: 1px; padding: 5px;">ON/OFF</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_3D\_ENABLED</td><td style="border-width: 1px; padding: 5px;">Enables Cander engine's 3D elements.</td><td style="border-width: 1px; padding: 5px;">ON/OFF</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_VRAM\_ALLOCATOR\_CHECK\_ENABLED</td><td style="border-width: 1px; padding: 5px;">
</td><td style="border-width: 1px; padding: 5px;">ON/OFF</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_VRAM\_ALLOCATOR\_STATISTICS\_ENABLED</td><td style="border-width: 1px; padding: 5px;">
</td><td style="border-width: 1px; padding: 5px;">ON/OFF</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_RENDER\_STATE\_CACHING\_ENABLED</td><td style="border-width: 1px; padding: 5px;">Whether or not [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") shall cache render states.
<dl class="note"><dt></dt><dd><p class="callout info">For SceneComposer builds (on host), render state caching must be disabled.</p>
<p class="callout info">For target builds, take care to enable this feature!</p>
</dd></dl></td><td style="border-width: 1px; padding: 5px;">ON/OFF
</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_DETAIL\_STATISTICS\_ENABLED</td><td style="border-width: 1px; padding: 5px;">Whether or not [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") shall keep statistics about render state cache hits and misses.
<dl class="note"><dt></dt><dd><p class="callout info">This works only if CANDERA\_RENDER\_STATE\_CACHING\_ENABLED is enabled.</p>
<p class="callout info">For target builds, disable because of the added overhead!</p>
</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_GLOBALIZATION\_ENABLED</td><td style="border-width: 1px; padding: 5px;">Whether or not [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") Globalization library shall be built.
<dl class="note"><dt></dt><dd><p class="callout info">[Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") Globalization is an optional module only available upon special request.</p>
</dd></dl></td><td style="border-width: 1px; padding: 5px;">ON/OFF</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_ASSET\_DECOMPRESSION\_ENABLED</td><td style="border-width: 1px; padding: 5px;">This option is required to decompress asset data if it was compressed with CGI Studio Asset Library Shaper previously. <dl class="note"><dt>
</dt><dd><p class="callout info">Enabling this feature will automatically add ZLib to the project.</p>
</dd></dl></td><td style="border-width: 1px; padding: 5px;">ON/OFF</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_TEXT\_SHAPER</td><td style="border-width: 1px; padding: 5px;">Allows the selection of a text shaper.
A text shaper resolves certain text features like text direction, context specific substitutions and ligatures.
Options:
- **HarfBuzz (Default)(Optional)**: Unidirectional text. Unicode defined substitutions. Unicode defined ligature, GSUB and GPOS lookup. <dl class="note"><dt></dt><dd><p class="callout info">HarfBuzz shaping is an optional module only available upon special request. Upon failure to detect the HarfBuzz source location, CMake will display "ComplexScripLib" as default textshaping option.</p>
    </dd></dl>
- **ComplexScriptLib**: Bidirectional text. Arabic context substitutions. Forced Unicode defined ligatures.
- **NoShaping**: Disables shaping. Text will be displayed left to right. No substitutions or ligatures are resolved.
</td><td style="border-width: 1px; padding: 5px;">NoShaping
ComplexScriptLib
Harfbuzz - *Default*
</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_BIDIRECTIONAL\_TEXT\_ENABLED</td><td style="border-width: 1px; padding: 5px;">Allows enabling of bidirectional text parsing.
This is needed when combining text written left to right with text written right to left.
If the text shaper supports bidirectional text this option is required when using multi-font text styles.</td><td style="border-width: 1px; padding: 5px;">ON/OFF
</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_TEXTENGINE\_NATIVE\_LINEHEIGHT\_ENABLED</td><td style="border-width: 1px; padding: 5px;">Whether or not the native line height metrics of the font engine is used.
If disabled then 120% of EM size is applied as line height which is compatible with Adobe.</td><td style="border-width: 1px; padding: 5px;">ON/OFF</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_ASSETLOADER\_MEMORYPOOL\_ENABLED</td><td style="border-width: 1px; padding: 5px;">Enables the use of the Memory Pool feature in [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") AssetLoader.
<dl class="note"><dt></dt><dd>Requires the MemoryPool feature. <p class="callout info">Only available if FEATSTD\_MEMORYPOOL\_ENABLED is ON.</p>
</dd></dl></td><td style="border-width: 1px; padding: 5px;">ON/OFF</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_TEXTENGINE\_MEMORYPOOL\_ENABLED</td><td style="border-width: 1px; padding: 5px;">Enables the use of the Memory Pool feature in [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") TextEngine.
<dl class="note"><dt></dt><dd>Requires the MemoryPool feature.</dd><dd><p class="callout info">Only available if FEATSTD\_MEMORYPOOL\_ENABLED is ON.</p>
</dd></dl></td><td style="border-width: 1px; padding: 5px;">ON/OFF</td></tr><tr><td style="border-width: 1px; padding: 5px;">CANDERA\_ASSET\_LIBRARYHEADER\_CACHE\_ENABLED</td><td style="border-width: 1px; padding: 5px;">Optional feature which will cache all Asset-Library-Header that have been loaded and cached upon Asset initialization.
<dl class="note"><dt></dt><dd>If dynamic Asset-Partitions are being used, caching will occur when a partition is added, and will continue until it is removed. <p class="callout info">The cache will use the standard Asset Cache memory.</p>
</dd></dl></td><td style="border-width: 1px; padding: 5px;">ON/OFF</td></tr></tbody></table>
</div></div></div>#### <a class="anchor" id="bkmrk--0"></a>Select FeatStd Features
For information about FeastStd features, please refer to <span style="color: rgb(230, 126, 35);">[FeatStd &gt; FeatStd Features](https://doc316en.candera.eu/books/featstd/page/featstd-features "FeatStd Features")</span>.
# 3rd Party Software: FreeType2 Configuration
3<sup>rd</sup> party software FreeType2 is used by the [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") Engine and can be configured in CMake like this:
<div class="contents" id="bkmrk-name-description-pos"><div class="textblock"><table border="1" cellpadding="5" cellspacing="0" width="800"><tbody><tr bgcolor="#d4d4d4"><th>**Name**</th><th>**Description**</th><th>**Possible values**</th></tr><tr><td>FREETYPE2\_CUSTOMIZE</td><td>Enable or disable FreeType2 customization.</td><td>ON/OFF</td></tr><tr><td>FREETYPE2\_FORCE\_DEFAULT\_CONFIG</td><td>Set all Freetype2 configuration flags such that the outcome is equivalent to using the "freetype/include/config/" files.</td><td>ON/OFF</td></tr><tr><td>FREETYPE2\_FORCE\_CANDERA\_CONFIG</td><td>Set all Freetype2 configuration flags such that the outcome is equivalent to using "Candera/TextEngine/FreeType/FtCda\*.h" files.</td><td>ON/OFF</td></tr><tr><td>FREETYPE2\_FORCE\_EMPTY\_CONFIG</td><td>Clears all Freetype2 configuration flags.</td><td>ON/OFF</td></tr><tr><td>FREETYPE2\_FORCE\_LIGHT\_CONFIG</td><td>Set all Freetype2 configuration flags to a minimal setting that provides support for using TrueType fonts and anti-aliased rendering with a minimal code size.</td><td>ON/OFF</td></tr></tbody></table>
</div></div><div class="contents" id="bkmrk-the-%22light%22-configur"><div class="textblock"><dl class="note"><dd></dd><dd><p class="callout info">The "light" configuration (FREETYPE2\_FORCE\_LIGHT\_CONFIG) does not support rendering of Opentype fonts. However, a rather minimal configuration with Opentype support is possible by enabling the following flags on top of the "light" configuration:
 FREETYPE2\_MODLOAD\_DRIVER\_CFF
 FREETYPE2\_MODLOAD\_MODULE\_PSAUX
 FREETYPE2\_MODLOAD\_MODULE\_PSHINTER
 FREETYPE2\_MODLOAD\_MODULE\_PSNAMES
 FREETYPE2\_OPT\_FT\_CONFIG\_OPTION\_POSTSCRIPT\_NAMES
 FREETYPE2\_OPT\_TT\_CONFIG\_OPTION\_POSTSCRIPT\_NAMES The exact features are font specific. The fastest way to evaluate the minimal module set requirements for a font is to get in contact with the font designer.</p>
# Candera Device Packages
#### <a class="anchor" id="bkmrk--1"></a>Supported Device Packages
[Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") provides device implementations for following device types:
<div class="contents" id="bkmrk-name-description-pos"><div class="contents"><div class="textblock"><table border="1" cellpadding="5" cellspacing="0" style="border-collapse: collapse; width: 800px; height: 59.5938px; border-width: 1px; border-spacing: 0px;" width="900"><tbody><tr bgcolor="#d4d4d4" style="height: 29.7969px;"><th style="height: 29.7969px; border-width: 1px; padding: 5px;">**Name**</th><th style="height: 29.7969px; border-width: 1px; padding: 5px;">**Description**</th><th style="height: 29.7969px; border-width: 1px; padding: 5px;">**Possible values**</th></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px; border-width: 1px; padding: 5px;">Other proprietary devices</td><td style="height: 29.7969px; border-width: 1px; padding: 5px;">Can be provided upon special request</td><td style="height: 29.7969px; border-width: 1px; padding: 5px;">ON/OFF</td></tr></tbody></table>
</div></div></div><div class="contents" id="bkmrk--0"><div class="contents"><div class="textblock">---
</div></div></div>#### <a class="anchor" id="bkmrk--2"></a>Device-Specific CMake Settings
<div class="contents" id="bkmrk-name-description-pos-0"><div class="contents"><div class="textblock"><table border="1" cellpadding="5" cellspacing="0" style="border-collapse: collapse; width: 800px; height: 369.14px; border-width: 1px; border-spacing: 0px;" width="900"><tbody><tr bgcolor="#d4d4d4" style="height: 29.7969px;"><th style="height: 29.7969px; border-width: 1px; padding: 5px;">**Name**</th><th style="height: 29.7969px; border-width: 1px; padding: 5px;">**Description**</th><th style="height: 29.7969px; border-width: 1px; padding: 5px;">**Possible values**</th></tr><tr style="height: 102.578px;"><td style="height: 102.578px; border-width: 1px; padding: 5px;">CGIDEVICE\_NAME</td><td style="height: 102.578px; border-width: 1px; padding: 5px;">The name of the device package</td><td style="height: 102.578px; border-width: 1px; padding: 5px;">Each device package following the [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") device CMake rules provided in the folder &lt;CANDERA\_SRC&gt;/CanderaPlatform/Device</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px; border-width: 1px; padding: 5px;">CGIDEVICE\_TARGET\_BUILD</td><td style="height: 29.7969px; border-width: 1px; padding: 5px;">Enable or disable building for target</td><td style="height: 29.7969px; border-width: 1px; padding: 5px;">ON/OFF</td></tr><tr style="height: 80.1875px;"><td style="height: 80.1875px; border-width: 1px; padding: 5px;">CGISTUDIO\_PATH\_3RD\_PARTY</td><td style="height: 80.1875px; border-width: 1px; padding: 5px;">Path to the 3rd party repository location</td><td style="height: 80.1875px; border-width: 1px; padding: 5px;">A string value containing the system file location of 3rd party software, auto-detected by finding possible locations of the name "\[ic01\_\]cgi\_studio\_3psw"</td></tr><tr style="height: 63.3906px;"><td style="height: 63.3906px; border-width: 1px; padding: 5px;">CGIDEVICE\_TARGET\_
&lt;CGIDEVICE\_NAME&gt;
\_DRIVER\_PATH\_INCLUDE</td><td style="height: 63.3906px; border-width: 1px; padding: 5px;">If you don't use the default driver path, the path to the driver include directory can be changed with this setting.</td><td style="height: 63.3906px; border-width: 1px; padding: 5px;">Path to driver include directory (by default set to include directory in 3rd party repository)</td></tr><tr style="height: 63.3906px;"><td style="height: 63.3906px; border-width: 1px; padding: 5px;">CGIDEVICE\_TARGET\_
\_DRIVER\_PATH\_LIB</td><td style="height: 63.3906px; border-width: 1px; padding: 5px;">If you don't use the default driver path, the path to the driver library directory can be changed with this setting.</td><td style="height: 63.3906px; border-width: 1px; padding: 5px;">Path to driver library directory (by default set to library directory in 3rd party repository)</td></tr></tbody></table>
</div></div></div>
To build a certain device package selected it from the drop-down list of the CMake property **"CGIDEVICE\_NAME"**:
For each device package, either building OpenGL based host simulation or target binaries can be selected via the Boolean CMake property ***"CGIDEVICE\_TARGET\_BUILD"***.
The following table illustrates configurations available for the supported device package:
<div class="contents" id="bkmrk-cgidevice_name-cgide"><div class="contents"><div class="textblock"><table border="1" cellpadding="5" cellspacing="0" style="border-collapse: collapse; width: 800px; border-width: 1px; border-spacing: 0px;" width="900"><tbody><tr bgcolor="#d4d4d4"><th style="border-width: 1px; padding: 5px;">CGIDEVICE\_NAME</th><th style="border-width: 1px; padding: 5px;">CGIDEVICE\_TARGET\_BUILD</th><th style="border-width: 1px; padding: 5px;">PUB\_CGI\_CPU</th><th style="border-width: 1px; padding: 5px;">PUB\_CGI\_OS</th><th style="border-width: 1px; padding: 5px;">Default driver path following
&lt;CGISTUDIO\_PATH\_3RD\_PARTY&gt;
/\[src/lib\]/</th></tr></tbody></table>
</div></div></div>The CMake properties "PUB\_CGI\_CPU", "PUB\_CGI\_OS" usually cannot be configured via the CMake user interface, but are autonomously detected by
the build system. The same applies for the variable "PUB\_CGI\_COMPILER".
If you don't use the CGI Studio 3rd party software folder structure, the driver paths can be specified in the variables
<div class="contents" id="bkmrk-cgidevice_target_%3Ccg"><div class="contents"><div class="textblock">- CGIDEVICE\_TARGET\_&lt;CGIDEVICE\_NAME&gt;\_DRIVER\_PATH\_INCLUDE and
- CGIDEVICE\_TARGET\_&lt;CGIDEVICE\_NAME &gt;\_DRIVER\_PATH\_LIB
</div></div></div>Depending on these properties, either MS Visual Studio solutions or Unix makefiles will be generated into the specified build
directory.
# Integrate Candera into Custom Build Environments
#### <a class="anchor" id="bkmrk--1"></a>Integrate Candera into Custom Build Environments
For building [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") as part of the Player demo application, please refer to <span style="color: rgb(230, 126, 35);">[Building the Player](https://doc316en.candera.eu/books/build-system-setup/chapter/building-player-widgets-and-schost)</span>.
If a custom application should include [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") libraries, this chapter explains the CGI-Studio library build process. To simplify integration of [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") source code into a custom build environment references to [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") compile switches are given below.
</div></div></div>#### <a class="anchor" id="bkmrk--2"></a>Build Cgi-Studio Candera libraries with CMake
Use CMake to create a Visual Studio solution for host or any other build environment (like make files for targets) and build [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") libraries.
<div class="contents" id="bkmrk-start-cmake-point-%22w"><div class="contents"><div class="textblock">1. Start CMake
2. Point "Where is the source code" to *&lt;cgi-studio-root&gt;/cgi\_studio\_candera/src*
3. Point "Where to build the binaries" to *&lt;cgi-studio-root&gt;/cgi\_studio\_candera/build*. Note that the name of the build directory can be freely chosen but it is required to create it on the same directory level as "src". Avoid blanks in the path
4. Click "Configure" and select the proper generator for the desired build environment.
    &gt; As an example, for host builds using Visual Studio 2010, select "Visual Studio 10".
    &gt; For target builds, please refer to the given target-specific setup documentation part of CGI Studio releases.
5. Confirm the dialog with OK. All [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") CMake settings which can be configured will appear in the main window, having red lines for all settings to be confirmed.
6. Check and modify the [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") CMake properties and click "Configure" again
7. As long as red lines are visible, those lines must be confirmed by clicking "Configure" again.
8. If no more red lines are visible, the "Generate" button is enabled. Click "Generate" to create the Visual Studio solution (or the make files for make-based build environments).
</div></div></div>Build [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") with the CMake-generated build environment (Visual Studio solution for host, e.g.).
<p class="callout info">Candera libraries will be available in the separate folders in the given build directory.
To collect all of the libraries in a specific folder, an output path can be specified during CMake configuration:
 - Tick the "Advanced" checkbox in the CMake GUI.
 - After pressing "Configure", the CMake property "CANDERA\_ENABLE\_LIBRARY\_OUTPUT" will become visible. Tick this and press "Configure" again.
 - Specify the library output directory in the "LIBRARY\_OUTPUT\_PATH" CMake variable.</p>
<div class="contents" id="bkmrk--0"><div class="contents"><div class="textblock"><dl class="note"><dd></dd></dl>---
</div></div></div>#### <a class="anchor" id="bkmrk--3"></a>Integrate Candera Source Code (Compile Switches)
When [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") source code is built using [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") CMake configuration, all relevant compile switches (defines) are already set by CMake. The template CanderaConfig.h.template (refer to *&lt;cgi\_studio\_root&gt;/cgi\_studio\_candera/cmake/templates*) is used by CMake to generate the file CanderaConfig.h in the build directory.
If [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") source code is built using a custom build environment, learn about all configuration defines available for [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") in the [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "[DataBinding_RefTypeSample]") API Documentation:
<div class="contents" id="bkmrk-candera_api_document"><div class="textblock">- [CANDERA\_API\_DOCUMENTATION/CANDERA GRAPHIC ENGINE/CANDERA CONFIGURATION](http://dev.doc.cgistudio.at/APILINK/group___config.html)
</div></div>
