# Smart Importer Best Practices
# Introduction
<span lang="EN-US">The Smart Importer will allow you to easily and quickly import digital assets to your solution. With AI assistance, you can assign functional HMI controls to elements within your design in a straightforward manner. Several other useful features are included, such as layer merging or multi-scene support. </span>
<span lang="EN-US"> </span><span lang="EN-US">This document explains how to configure the layer structure on PSD file in order to effectively use Control mapping by Smart Importer.</span>
<span lang="EN-US"> </span><span lang="EN-US">The IVI sample, which is partially explained in this document, is attached on this PDF.</span>
# Recommended PSD Layers Structure for Smart Importer
<span lang="EN-US">When creating PSD files using Adobe Photoshop, it is recommended that the naming and structure of the Photoshop layer controls be pre-matched to SceneComposer. </span><span lang="EN-US">This will allow for smooth application of controls and their properties when importing with SmartImporter. </span><span lang="EN-US">The list below shows the Controls that will be assigned in Scene Composer via Smart Importer. Press the links on each Control to jump to the page showing the recommended layer structure in detail. </span>
<span lang="EN-US">It is important to note that the Smart Importer cannot process effects, masks, filters in Photoshop. Therefore, if you want to use these features, please rasterize the images in advance. </span>
<span lang="EN-US"> </span><span lang="EN-US">Some Controls are included in the sample file "IVI\_Sample.psd" and are explained with specific examples.</span>
<div align="center" id="bkmrk-"></div>---
#### <span style="mso-bookmark: _Toc60916595;"><span style="mso-bookmark: _Toc1141787;"><span style="mso-bookmark: _Toc535854259;"><span style="mso-bookmark: _Toc535852673;"><span style="mso-bookmark: _Toc531273511;"><span style="mso-bookmark: _Toc531273498;"><span lang="EN-US">PSD layer settings for Control</span></span></span></span></span></span></span>
<span lang="EN-US">In this section, the recommended layer configuration in PSD file is described for each control. And, you can confirm its configuration in the sample file about CheckBox, Gauge, IconButton, RadioButton, and TextButton.</span>
- <span lang="EN-US">Setting Group name is optional, but it is recommended to use the Control name (as seen in Scene Composer)</span>
- <span lang="EN-US">It is also recommended to use the property names (as seen in Scene Composer) as layer names (in Photoshop), but please don't use spaces in the layer names.</span>
<div drawio-diagram="7182"><img src="https://doc316en.candera.eu/uploads/images/drawio/2024-10/drawing-5-1729869873.png" alt=""/></div>
<span lang="EN-US" style="mso-fareast-language: ZH-CN;"> </span>
#### <span style="mso-bookmark: _Toc108634651;"><span style="mso-bookmark: _Toc108695611;"><span lang="EN-US">CheckBox</span></span></span>
<span lang="EN-US">The CheckBox Control can easily be configured with a text, images for a normal and a pressed state as well as for a selected and a selected pressed state.</span><span lang="EN-US"> </span>
<div drawio-diagram="2994"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678067559.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-checkbox-"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; width: 47.9012%; height: 116.953px; border-width: 1px; border-spacing: 0px; background-color: #ffffff; border-color: #000000;"><tbody><tr style="height: 23.3906px;"><td style="width: 32.0886%; border: 1px solid rgb(0, 0, 0); background: rgb(31, 73, 125); padding: 0mm 5.4pt; height: 23.3906px;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 67.9154%; border-width: 1px; border-style: solid solid solid none; border-color: rgb(0, 0, 0); border-image: initial; background: transparent; padding: 0mm 5.4pt; height: 23.3906px;" valign="top" width="255"><span lang="EN-US">CheckBox</span>
</td></tr><tr style="height: 23.3906px;"><td rowspan="4" style="width: 32.0886%; border-width: 1px; border-style: none solid solid; border-color: rgb(0, 0, 0); border-image: initial; background: rgb(31, 73, 125); padding: 0mm 5.4pt; height: 93.5624px;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Layer</span>
</td><td style="width: 67.9154%; border-width: 1px; border-style: none solid solid none; border-color: rgb(0, 0, 0); background: transparent; padding: 0mm 5.4pt; height: 23.3906px;" valign="top" width="255"><span lang="EN-US">SelectedImage</span>
</td></tr><tr style="height: 23.3906px;"><td style="width: 67.9154%; border-width: 1px; border-style: none solid solid none; border-color: rgb(0, 0, 0); background: transparent; padding: 0mm 5.4pt; height: 23.3906px;" valign="top" width="255"><span lang="EN-US">SelectedPressedImage</span>
</td></tr><tr style="height: 23.3906px;"><td style="width: 67.9154%; border-width: 1px; border-style: none solid solid none; border-color: rgb(0, 0, 0); background: transparent; padding: 0mm 5.4pt; height: 23.3906px;" valign="top" width="255"><span lang="EN-US">NormalImage</span>
</td></tr><tr style="height: 23.3906px;"><td style="width: 67.9154%; border-width: 1px; border-style: none solid solid none; border-color: rgb(0, 0, 0); background: transparent; padding: 0mm 5.4pt; height: 23.3906px;" valign="top" width="255"><span lang="EN-US">PressedImage</span>
</td></tr></tbody></table>
</div><span lang="EN-US"> </span>
<div drawio-diagram="2997"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678067649.png" alt=""/></div>
<div align="center" id="bkmrk--4"></div>#### <span style="mso-bookmark: _Toc108634652;"><span style="mso-bookmark: _Toc108695612;"><span lang="EN-US">Gauge</span></span></span>
<span lang="EN-US">The Gauge allows to rotate a needle on a background according to its input value.</span>
<div drawio-diagram="2995"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678067570.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-gauge-lay"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-width: 1px; border-spacing: 0px;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border-width: 1px; border-style: solid; border-image: initial; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">Gauge</span>
</td></tr><tr style="mso-yfti-irow: 1;"><td rowspan="2" style="width: 99.25pt; border-width: 1px; border-style: none solid solid; border-image: initial; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Layer</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">NeedleImage </span>
</td></tr><tr style="mso-yfti-irow: 2; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">BackgroundImage </span>
<div drawio-diagram="7183"><img src="https://doc316en.candera.eu/uploads/images/drawio/2024-10/drawing-5-1729870561.png" alt=""/></div>
<div align="center" id="bkmrk-layer-structure-in-p"></div><span lang="EN-US"> </span>
<span lang="EN-US" style="mso-fareast-language: ZH-CN;"><span lang="EN-US" style="font-size: 10.0pt; font-family: 'Calibri',sans-serif; mso-fareast-font-family: 'Meiryo UI'; mso-bidi-font-family: 'Segoe UI'; mso-bidi-theme-font: major-latin; mso-ansi-language: EN-US; mso-fareast-language: JA; mso-bidi-language: AR-SA;">
</span></span>
#### <span style="mso-bookmark: _Toc108634653;"><span style="mso-bookmark: _Toc108695613;"><span lang="EN-US">IconButton</span></span></span>
<span lang="EN-US">IconButton has similar functionality as the standard button, but in addition an icon (image) is placed on top of the button.</span>
<div drawio-diagram="2998"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678067698.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-iconbutto"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">IconButton</span>
</td></tr><tr style="mso-yfti-irow: 1;"><td rowspan="5" style="width: 99.25pt; border-width: 1px; border-style: none solid solid; border-color: initial; border-image: initial; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Layer</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">NormalImage </span>
</td></tr><tr style="mso-yfti-irow: 2;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">PressedImage </span>
</td></tr><tr style="mso-yfti-irow: 3;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">FocusedImage </span>
</td></tr><tr style="mso-yfti-irow: 4;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">IconNormalImage </span>
</td></tr><tr style="mso-yfti-irow: 5; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">IconPressedImage </span>
<div drawio-diagram="7185"><img src="https://doc316en.candera.eu/uploads/images/drawio/2024-10/drawing-5-1729870805.png" alt=""/></div>
<div align="center" id="bkmrk-layer-structure-in-p-0"></div><span lang="EN-US"> </span>
#### <span style="mso-bookmark: _Toc108634654;"><span style="mso-bookmark: _Toc108695614;"><span lang="EN-US">RadioButton</span></span></span>
<span lang="EN-US">The RadioButton Control can easily be configured with a text, images for a normal and a pressed state as well as for a selected and a selected pressed state.</span>
<div drawio-diagram="3000"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678071560.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-radiobutt"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; width: 47.9012%; height: 140.344px; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="height: 23.3906px;"><td style="width: 0%; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt; height: 23.3906px;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 0%; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt; height: 23.3906px;" valign="top" width="255"><span lang="EN-US">RadioButton</span>
</td></tr><tr style="height: 23.3906px;"><td rowspan="5" style="width: 0%; border-width: 1px; border-style: none solid solid; border-color: initial; border-image: initial; background: rgb(31, 73, 125); padding: 0mm 5.4pt; height: 116.953px;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Layer</span>
</td><td style="width: 0%; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt; height: 23.3906px;" width="255"><span lang="EN-US">NormalImage </span>
</td></tr><tr style="height: 23.3906px;"><td style="width: 0%; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt; height: 23.3906px;" width="255"><span lang="EN-US">PressedImage </span>
</td></tr><tr style="height: 23.3906px;"><td style="width: 0%; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt; height: 23.3906px;" width="255"><span lang="EN-US">SelectedImage </span>
</td></tr><tr style="height: 23.3906px;"><td style="width: 0%; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt; height: 23.3906px;" width="255"><span lang="EN-US">SelectedPressedImage </span>
</td></tr><tr style="height: 23.3906px;"><td style="width: 0%; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt; height: 23.3906px;" width="255"><span lang="EN-US">FocusedImage </span>
<span lang="EN-US">RadioButton (In the image, it is RadioButton\_Outside\_air to distinguish it.)
</span>
<div drawio-diagram="7186"><img src="https://doc316en.candera.eu/uploads/images/drawio/2024-10/drawing-5-1729870914.png" alt=""/></div>
#### <span style="mso-bookmark: _Toc108634655;"><span style="mso-bookmark: _Toc108695615;"><span lang="EN-US">TextButton</span></span></span>
<span lang="EN-US">The TextButton Control offers an easy way to define all different states of a button and an action that is performed when clicking it.</span>
<div drawio-diagram="3004"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678071726.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-textbutto"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">TextButton </span>
</td></tr><tr style="mso-yfti-irow: 1;"><td rowspan="3" style="width: 99.25pt; border-width: 1px; border-style: none solid solid; border-color: initial; border-image: initial; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Layer</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">NormalImage </span>
</td></tr><tr style="mso-yfti-irow: 2;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">PressdImage</span>
</td></tr><tr style="mso-yfti-irow: 3; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">FocusedImage </span>
<div drawio-diagram="7187"><img src="https://doc316en.candera.eu/uploads/images/drawio/2024-10/drawing-5-1729871075.png" alt=""/></div>
#### <span style="mso-bookmark: _Toc108634656;"><span style="mso-bookmark: _Toc108695616;"><span lang="EN-US">AnalogClock</span></span></span>
<span lang="EN-US">An analog clock with images for the certain needles (hours, minutes, seconds).</span>
<div drawio-diagram="3006"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678071802.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-analogclo"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">AnalogClock</span>
</td></tr><tr style="mso-yfti-irow: 1;"><td rowspan="4" style="width: 99.25pt; border-width: 1px; border-style: none solid solid; border-color: initial; border-image: initial; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Layer</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">SecondsNeedleImage </span>
</td></tr><tr style="mso-yfti-irow: 2;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">MinutesNeedleImage </span>
</td></tr><tr style="mso-yfti-irow: 3;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">HoursNeedleImage </span>
</td></tr><tr style="mso-yfti-irow: 4; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">FaceImage </span>
</span></span>
#### <span style="mso-bookmark: _Toc108634657;"><span style="mso-bookmark: _Toc108695617;"><span lang="EN-US">Breadcrumb</span></span></span>
<span lang="EN-US">A Breadcrumb shows the history/flow through the screen hierarchy and allows user, for example, to navigate between scenes using breadcrumb's elements.</span>
<div drawio-diagram="3007"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678071840.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-breadcrum"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">Breadcrumb</span>
</td></tr><tr style="mso-yfti-irow: 1;"><td rowspan="2" style="width: 99.25pt; border-width: 1px; border-style: none solid solid; border-color: initial; border-image: initial; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Layer</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">Name </span>
</td></tr><tr style="mso-yfti-irow: 2; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">EllipsisText </span>
#### <span style="mso-bookmark: _Toc108634658;"><span style="mso-bookmark: _Toc108695618;"><span lang="EN-US">Button</span></span></span>
<span lang="EN-US">The Button Control offers an easy way to define all different states of a button and an action that is performed when clicking it.</span>
<div drawio-diagram="3008"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678071873.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-button-la"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">Button</span>
</td></tr><tr style="mso-yfti-irow: 3; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">FocusImage </span>
#### <span style="mso-bookmark: _Toc108634659;"><span style="mso-bookmark: _Toc108695619;"><span lang="EN-US">CircularSlider</span></span></span>
<span lang="EN-US">Circular slider is a control that allows user to set the value using circular slide movement or directly indicate value on slider's bar.</span>
<div drawio-diagram="3009"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678071906.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-circulars"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1; background: #1F497D; mso-shading-themecolor: text2;">Group nam</span><span lang="EN-US" style="color: white; mso-themecolor: background1;">e</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">CircularSlider</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">BackgroundImage </span>
</td></tr><tr style="mso-yfti-irow: 2;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">ActiveImage </span>
</td></tr><tr style="mso-yfti-irow: 3;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">ThumbImage </span>
</td></tr><tr style="mso-yfti-irow: 4;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">ThumbImagePressed </span>
</td></tr><tr style="mso-yfti-irow: 5; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">FocusImage </span>
#### <span style="mso-bookmark: _Toc108634660;"><span style="mso-bookmark: _Toc108695620;"><span lang="EN-US">GroupBox</span></span></span>
<span lang="EN-US">The GroupBox offers an easy way to combine RadioButtons to a RadioButtonGroup.</span>
<div align="center" id="bkmrk-group-name-groupbox-"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">GroupBox</span>
</td></tr><tr style="mso-yfti-irow: 1; mso-yfti-lastrow: yes;"><td style="width: 99.25pt; border-width: 1px; border-style: none solid solid; border-color: initial; border-image: initial; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Layer</span>
#### <span style="mso-bookmark: _Toc108634661;"><span style="mso-bookmark: _Toc108695621;"><span lang="EN-US">InputField</span></span></span>
<span lang="EN-US">The InputField contains an editable text.</span>
<div align="center" id="bkmrk-group-name-inputfiel"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">InputField</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">CaretImage </span>
</td></tr><tr style="mso-yfti-irow: 2;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">BackgroundImage </span>
</td></tr><tr style="mso-yfti-irow: 3; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">FocusedImage </span>
</div><span lang="EN-US" style="mso-fareast-language: ZH-CN;"><span lang="EN-US" style="font-size: 10.0pt; font-family: 'Calibri',sans-serif; mso-fareast-font-family: 'Meiryo UI'; mso-bidi-font-family: 'Segoe UI'; mso-bidi-theme-font: major-latin; mso-ansi-language: EN-US; mso-fareast-language: JA; mso-bidi-language: AR-SA;">
</span></span>
#### <span style="mso-bookmark: _Toc108634662;"><span style="mso-bookmark: _Toc108695622;"><span lang="EN-US">Menu Icon</span></span></span>
<span lang="EN-US">The MenuIcon Control is an “icon” like in graphical environments of most known operating systems.</span>
<div align="center" id="bkmrk-group-name-menuicon-"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">MenuIcon</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">Image </span>
</td></tr><tr style="mso-yfti-irow: 2; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">BackgroundImage </span>
#### <span style="mso-bookmark: _Toc108634663;"><span style="mso-bookmark: _Toc108695623;"><span lang="EN-US">Menu Item</span></span></span>
<span lang="EN-US">A MenuItem is a basic building block of MenuScreens. It can represent for example an application or a deeper level in a menu hierarchy.</span>
<div drawio-diagram="3011"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678071982.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-menuitem-"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">MenuItem</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">FocusImageOnSelection </span>
</td></tr><tr style="mso-yfti-irow: 2;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">FocusImageOnDragging </span>
</td></tr><tr style="mso-yfti-irow: 3;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">DeleteButtonNormalImage </span>
</td></tr><tr style="mso-yfti-irow: 4;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">DeleteButtonPressedImage </span>
</td></tr><tr style="mso-yfti-irow: 5; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">Image </span>
</span></span>
#### <span style="mso-bookmark: _Toc108634664;"><span style="mso-bookmark: _Toc108695624;"><span lang="EN-US">Menu Screen</span></span></span>
<span lang="EN-US">The Control represents a menu in the form of a grid of icons (instances of the Menu Item Control).</span>
<div drawio-diagram="3012"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678072052.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-menuscree"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">MenuScreen</span>
</td></tr><tr style="mso-yfti-irow: 2; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">FocusBorderImage </span>
#### <span style="mso-bookmark: _Toc108634665;"><span style="mso-bookmark: _Toc108695625;"><span lang="EN-US">Mesh2D</span></span></span>
<span lang="EN-US">Performs a perspective projection of a 3D rotated effect based on the configured origin, rotation and field of view.</span>
<div drawio-diagram="3013"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678072078.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-mesh2d-la"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">Mesh2D</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">Image</span>
#### <span style="mso-bookmark: _Toc108634666;"><span style="mso-bookmark: _Toc108695626;"><span lang="EN-US">MultiStateButton</span></span></span>
<span lang="EN-US">The MultiStateButton Control offers an easy way to define all different states of a button.</span>
<div align="center" id="bkmrk-group-name-multistat"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">MultiStateButton</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">ButtonState1Bmp </span>
</td></tr><tr style="mso-yfti-irow: 2;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">ButtonState2Bmp </span>
</td></tr><tr style="mso-yfti-irow: 3;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">ButtonState3Bmp </span>
</td></tr><tr style="mso-yfti-irow: 4;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">ButtonState4Bmp </span>
</td></tr><tr style="mso-yfti-irow: 5; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">FocusedImage </span>
#### <span style="mso-bookmark: _Toc108634667;"><span style="mso-bookmark: _Toc108695627;"><span lang="EN-US">PageIndicator</span></span></span>
<span lang="EN-US">A Page Indicator is a control that indicates currently visible page of set and provides method to switch to another page directly by click or if focused on a stepping manner using rotary action input.</span>
<div drawio-diagram="3014"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678072124.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-pageindic"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">PageIndicator</span>
</td></tr><tr style="mso-yfti-irow: 1;"><td rowspan="6" style="width: 99.25pt; border-width: 1px; border-style: none solid solid; border-color: initial; border-image: initial; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Layer</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">PressedImage </span>
</td></tr><tr style="mso-yfti-irow: 2;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">SelectedPressedImage </span>
</td></tr><tr style="mso-yfti-irow: 3;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">SelectedIndicatorImage </span>
</td></tr><tr style="mso-yfti-irow: 4;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">IndicatorImage </span>
</td></tr><tr style="mso-yfti-irow: 5;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">SelectedIndicatorPressedImage </span>
</td></tr><tr style="mso-yfti-irow: 6; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">IndicatorPressedImage </span>
</span></span>
#### <span style="mso-bookmark: _Toc108634668;"><span style="mso-bookmark: _Toc108695628;"><span lang="EN-US">Roll</span></span></span>
<span lang="EN-US">The Control represents a vertical list of numeric values from a specified range with a specified step.</span>
<div drawio-diagram="3015"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678072174.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-roll-laye"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">Roll</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">DecorationImage </span>
</td></tr><tr style="mso-yfti-irow: 2; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">TextEditBackground </span>
#### <span style="color: rgb(0, 0, 0);"><span style="mso-bookmark: _Toc108695629;"><span lang="EN-US">S</span></span></span><span style="mso-bookmark: _Toc108634669;"><span style="mso-bookmark: _Toc108695629;"><span lang="EN-US">pinBox</span></span></span>
<span lang="EN-US">A spin box or spin button is a control that enables users to increase or decrease the number value by a specific increment via clicking an up or down arrow button.</span>
<div drawio-diagram="3016"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678072199.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-spinbox-l"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">SpinBox</span>
</td></tr><tr style="mso-yfti-irow: 2;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">ArrowUpNormalImage </span>
</td></tr><tr style="mso-yfti-irow: 3;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">ArrowUpPressedImage </span>
</td></tr><tr style="mso-yfti-irow: 4;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">ArrowDownNormalImage </span>
</td></tr><tr style="mso-yfti-irow: 5; mso-yfti-lastrow: yes;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">ArrowDownPressedImage </span>
</span></span>
#### <span style="mso-bookmark: _Toc108634670;"><span style="mso-bookmark: _Toc108695630;"><span lang="EN-US">ToggleButton</span></span></span>
<span lang="EN-US">The ToggleButton Control offers an easy way to define all different states of a toggle button and an action that is performed when clicking it.</span>
<div drawio-diagram="3017"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678072226.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-togglebut"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">ToggleButton</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">FirstImage </span>
</td></tr><tr style="mso-yfti-irow: 2;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">FirstPressedImage </span>
</td></tr><tr style="mso-yfti-irow: 3;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">SecondImage </span>
</td></tr><tr style="mso-yfti-irow: 4;"><td style="width: 191.35pt; border-width: 1px; border-style: none solid solid none; border-color: initial; padding: 0mm 5.4pt;" width="255"><span lang="EN-US">SecondPressedImage </span>
</div><div align="center" id="bkmrk--31"></div><div align="center" id="bkmrk--32"></div>
#### <span style="mso-bookmark: _Toc108634671;"><span style="mso-bookmark: _Toc108695631;"><span lang="EN-US">TouchIndication</span></span></span>
<span lang="EN-US">The TouchIndication indicates the location of touch events.</span>
<div drawio-diagram="3018"><img src="https://doc316en.candera.eu/uploads/images/drawio/2023-03/drawing-4-1678072253.png" alt=""/></div>
<div align="center" id="bkmrk-group-name-touchindi"><table border="1" cellpadding="0" cellspacing="0" class="align-left" style="border-collapse: collapse; border-spacing: 0px; border: 1px none initial;"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="width: 99.25pt; border: 1px solid; background: rgb(31, 73, 125); padding: 0mm 5.4pt;" valign="top" width="132"><span lang="EN-US" style="color: white; mso-themecolor: background1;">Group name</span>
</td><td style="width: 191.35pt; border-width: 1px; border-style: solid solid solid none; border-color: initial; border-image: initial; padding: 0mm 5.4pt;" valign="top" width="255"><span lang="EN-US">TouchIndication</span>
</div><span lang="EN-US"></span>
# Usage example (Importing and assigning Control)
<span lang="EN-US">In this section describes the Control assignment procedure when importing a PSD file with the layer structure described in the previous chapter. The file to be imported on Scene Composer is the IVI sample attached to this document. </span>
1. <span lang="EN-US" style="mso-fareast-language: ZH-CN;"> </span><span lang="EN-US" style="mso-fareast-language: ZH-CN;">From the menu bar on Scene Composer, select Import &gt; Smart Importer... on the menu bar and select a Photoshop file (IVI sample.psd).</span>
2. <span lang="EN-US" style="mso-fareast-language: ZH-CN;">Smart Importer dialog box appears.</span>
3. <span lang="EN-US" style="mso-fareast-language: ZH-CN;">Click on the group in the tree for which you want to set Control. In this example case, select TextButton\_Car to assign TextButton Control.</span>
4. Since its layer structure in Photoshop follows the structure of <span style="text-decoration: underline;"><span lang="EN-US" style="text-indent: -21pt; color: rgb(230, 126, 35); text-decoration: underline;">[Textbutton](https://doc316en.candera.eu/link/1156#bkmrk-textbutton)</span></span><span lang="EN-US" style="mso-fareast-language: ZH-CN;"><span lang="EN-US" style="mso-fareast-language: ZH-CN;"><span lang="EN-US" style="mso-fareast-language: ZH-CN;"> Control, Smart Importer's AI detects "TextButton" Control.
    </span></span></span><div drawio-diagram="7188"><img src="https://doc316en.candera.eu/uploads/images/drawio/2024-10/drawing-5-1729871206.png" alt=""/></div>
5. From the ControlList, click Apply button on the far right of the TextButton control to assign that Control.
- - - <span lang="EN-US" style="mso-fareast-font-family: SimSun; mso-fareast-language: ZH-CN;">Depends on its Control usage and/or Solution to be created, will set on "Appearance" and "Basic Properties" tabs.</span>
<span lang="EN-US" style="mso-fareast-font-family: SimSun; mso-fareast-language: ZH-CN;"> </span>
<span lang="EN-US" style="mso-fareast-font-family: SimSun; mso-fareast-language: ZH-CN;">As described above, you can efficiently import operations in Scene Composer by configuring the layer structure in Photoshop according to Controls you want to use.</span>
